airturk
Noise Analysis using PlanAhead
Dear Members;
I have a vhdl design and I am targeting a spartan6-slx150 using the ISE 12.4 toolset.
My question is related to pinout assignments and running the Noise Analysis tool using PlanAhead.
I run the planahead after the synthesis and perform DRC. The tool is happy and there are no error.
After I run the noise analysis, and then I see that the I/O Bank 0 fails the test with -55% remaining margin.
I think the solution to that is changing the IO Standard, or drive strength or off-chip termination, or moving some of the pins to another, less utilized, bank. I completely agree with all these solutions.
However, I really like to know how the tool figures out the load on these pins. Currently, I have 31 outputs, including Host Port, Master SPI, Slave SPI, GPIO lines, and JTAG. BUT, I know ~8 of them are used only in the startup, some of them are GPIO lines are used very infrequently.
How does the tool account for this?
Any insight, recommendation is appreciated.
tanders
Device limits are listed in the UG:
http://www.xilinx.com/support/documentation/data_sheets/ds162.pdfhttp://www.xilinx.com/support/documentation/data_sheets/ds162.pdf
For the calculations, there are many factures, including but not limited to: The bank, pwr/gnd pins, port/pin location, IOStandard, Drive, Termination, etc...  Ealier versions of software used a more conservative analysis that did not look at pin/port location.
tanders
