(PR-Impl error): [Route 35-451] Routing/Distribution Layer congestion detected on net AND [Constraints 18-1000] error.
Vivado 2019.1 Ultrascale+ Partial reconfiguration flow
During implementation I get Critical Warnings that lead to an error.
[Route 35-451] Routing/Distribution Layer congestion detected on net qsfp1_instance/inst/i_core_gtwiz_userclk_tx_inst_0/CLK
[Constraints 18-1000] Routing results verification failed due to partially-conflicted nets (Up to first 10 of violated nets):  qsfp1_instance/inst/i_core_gtwiz_userclk_rx_inst_0/CLK qsfp1_instance/inst/i_core_gtwiz_userclk_tx_inst_0/CLK prsfp2_instance/qsfp2_instance/inst/i_core_gtwiz_userclk_rx_inst_0/CLK prsfp2_instance/qsfp2_instance/inst/i_core_gtwiz_userclk_tx_inst_0/CLK
How can I debug that? I don't find any trace of Route 35-451 and Constraints 18-1000.
Thank you.
Tags (4)
Re: (PR-Impl error): [Route 35-451] Routing/Distribution Layer congestion detected on net AND [Constraints 18-1000] error.
Hi, @alexis_jp ,
Please confirm that the mentioned clock nets can be routed correctly in the non-PR flow first.
