12-16-2020 03:55 AM
I am moving my first steps in Partial Reconfiguration.
I implemented two very simple IP using Vivado HLS. (they write and read from a BRAM and are controlled by AXI Lite interfaces)
I want to build a reconfigurable design able to switch between the two IPs. The reconfiguration should be triggered by the processor system (I am using a Zynq), but I have issues in generating the partial bitstreams because I cannot complete the implementation due to the error:
ERROR: [DRC HDPR-41] Clock Net Rule Violation: Reconfigurable cell 'PR_platform_i/march_0' has a route-through (direct connection between input port and output port inside reconfigurable cell) driven by clock net 'PR_platform_i/pr_decoupler_0/U0/s_intf_0_CLK_BUFG'. This connection is not supported by partial reconfiguration flow. Resolution: Remove the clock net route-through by modifying the module interface.
But it is not very clear to me what it means with a route-through (direct connection between input port and output port inside reconfigurable cell).
As a first step, I synthesized both the configurations as "out_of_context".
Then, I started from the full design (including IP1), removing the reconfigurable module using update_design -black_box command to generate the static design.
Then I did floor planning, and set RESET_AFTER_RECONFIG 1 and SNAPPING_MODE ON.
Then, I combined the static with the first reconfigurable module (IP1) and I set HD.RECONFIGURABLE TRUE .
So, I performed place and route of the first design with config1.
Then I removed the RM using update_design -black-box and I locked the routing of the static design using lock_design -level routing.
I continued attaching the second config (IP2) to the static design using : read_checkpoint.
When we tried to do the place and route of the this design, I receive the error.
If I try to reuse the IP1 for the second configuration, I observe the same behavior.
I had the error also before inserting the decoupler (but an IP clock signal). I tried to move my pblock around and to insert the decoupler but it is still here.
I already tried several solution as the "update_design -cells [get_cells <my cell>] -buffer_ports" but it doesn't change anything. (probably because it is not very clear what is the issue).
I used block design.
12-19-2020 02:05 AM
Hi @marcb,
thankyou for your suggestions. I did that but I could not find the net going directly through the RM.
Anyway, I was using Vivado 2019. Yesterday, I tried on Vivado 2020 and it worked without any problem. So, it could be a problem related to the tool version.
12-17-2020 09:41 AM
Hi @corrado
To see what is causing the error, I would suggest the following:
According to the message, it should go directly through the Reconfigurable Module. To avoid this, prevent the global clock from exiting the RM (it already drives the static region).
12-19-2020 02:05 AM
Hi @marcb,
