Visitor venka_peri
RLOC RANGE in Vivado
Hi -
Is there a way to specify a range when constaining design elements in RTL?
I have a set of registers that I would like to constrain in my module. My (pseudo) code looks like:
module module_name
input.....
output.....
(* HU_SET = "uset0", RLOC = "X1Y0:X1Y1" , KEEP = "TRUE" *)  logic [15:0] ff1;
(* HU_SET = "uset0", RLOC = "X2Y0:X2Y1" , KEEP = "TRUE" *) logic [15:0] ff2;
always @ (posedge clk) begin
 ff1 <= exp1;
 ff2 <= exp2;
end
endmodule
I would like to place  ff1 and ff2 (16 flip-flops each) in contiguous slices one above the other - with 8 registers per slice
for a total of 4 slices. The above code does not work.
I get the desired result if I re-arrange/split my implementation to:
(* HU_SET = "uset0", RLOC = "X1Y0" , KEEP = "TRUE" *)  logic [15:8] ff1_msb;
(* HU_SET = "uset0", RLOC = "X1Y1" , KEEP = "TRUE" *)  logic [7:0] ff1_lsb;
(* HU_SET = "uset0", RLOC = "X2Y0" , KEEP = "TRUE" *) logic [15:8] ff2_msb;
(* HU_SET = "uset0", RLOC = "X2Y1" , KEEP = "TRUE" *) logic [7:0] ff2_lsb;
 I was curious to know if there is a way to pass an RLOC RANGE (in RTL in Vivado).
-Venka
