annu_shah
Re: Plan Ahead program is not launching.
hey i am having the same problem ,planahead is not opening meaning that its not installed properly what should i do kindly help
Annu shah
heidelberg university
vemulad
Which version of ISE are you using?
Are you able to open PlanAhead from start--> xilinx Design tools --> ISE design suite --> Planahead.
Deepika.
Deepika.
vemulad
Deepika.
Deepika.
annu_shah
thanks also i have one more issue i am trying to follow the hello world example but i get this error
Connection canceled due to ownership request from org.eclipse.debug.internal.cor
e.LaunchConfiguration.
kindly help
