02-21-2012 10:32 AM
I have a project that uses a block ram core from Xilinx Core Gen. I added the wrapper file and the file with .ngc extension to the plan ahead project using "add source". The ngc file shows up under Source->libraries->NGC->unreferenced->multiplier32X32Bits.ngc.
When I try to implement my netlist I get the following error:
[NgdBuild 604] logical block 'io_interface/dac_controller/dac_gain_mult' with type 'multiplier32x32bits' could not be resolved. A pin name misspelling can cause this, a missing edif or ngc file, case mismatch between the block name and the edif or ngc file name, or the misspelling of a type name. Symbol 'multiplier32x32bits' is not supported in target 'spartan3e'.
The same file compiles fine in project navigator (ISE) with macro search path set to the folder that contains that ngc file.
I should note that when I added the wrapper file and ngc file to the planahead project, I did not tick the box that said " copy to project folder"
Any ideas why planahead cannot locate the ngc properly.
I attached a picture of the error
Thanks a lot for any help resolving this issue.
Amish
02-23-2012 07:35 AM
For those who run into this issue in the future. This is the answer from the xilinx rep:
Under Translate/More add the follow "-sd C:\perforce\projects\DEV\E9318_SuperNova\P07_Compensator_FPGA_FASTDSP\Source\src\Cores\DPRAM256x32Bits
do this for all cores
-sd is basically setting macro search path like I use to do in project navigator (ISE).
Clearly planahead 13.3 is not smart enough to look for ngc file in the same directory as the .vhd wrapper
Hope this solves the issue. Thanks for help,
Amish
02-21-2012 10:49 AM
02-21-2012 02:58 PM
A bit of a "shot in the dark", but I believe the file name needs to exactly match the module name. You mentioned the file name had a lower case "bits" and the error complains about the module with an uppercase "Bits".
If this is not the issue, you may want to open a case with tech support to get someone to take a quick look at it.
02-22-2012 06:46 PM
As I know, it is a bug in 13.3. You can try to set the "Hierarchy Update" as 'No update" can solve that problem.
02-23-2012 07:35 AM
Amish
03-15-2012 07:48 AM
This behavior is by design. All sources that are to be used in a project should be added to the proejct. In this case the best option is to add the specific NGC files that you want the design to use to the project. This way there is no ambiquity about what files are being picked up (e.g. if you have duplicate NGCs in diferent diretories).
