vhdl component dependency graph
Is there a tool that can automatically parse VHDL files from a large project and make a dependency graph of files and components?
Frank
Re: vhdl component dependency graph
Hey @travellingwave,
Yes, there is! Check out VUnit.
Best,
Herbert
Thanks! I'm trying it out. I am familiar with python, so I could check up the source.
Frank
You're welcome!
All the best,
Herbert
Herbert,
I am having trouble to find the graph capability in
https://vunit.github.io/documentation.html
Vunit requires a simulator.https://vunit.github.io/cli.html#simulator-selection
the documentation talks about  activehdlrivieraproghdl, modelsim.
Is any with command line interface to a simulator already included in Vivado? When I installed GHDL and tried to run a vunit uart example, I get an error message saying ghdl can't find std library.
Frank
I am having trouble to find the graph capability ...
Check out project.py and the create_dependency_graph() function.
GHDL should work fine (including the std library) what options are you using?
Hope this helps,
Herbert
Hello @hpoetzl
I found create_dependency_graph() in the Project class. I can't find information to use this class. Can you please post a short example script?
My initial mistake is obvious. I ran python run.py without any options from the examples\vhdl\uart\ in the Windows command prompt.
Now, I try the examples\vhdl\user_guide\ mentioned in https://vunit.github.io/cli.html#example-session With python run.py -v lib.tb_example.all, I still get
The python run.py -l did work correctly as shown on the github page.
Frank
I ran successfully the GHDL example in:
http://ghdl.readthedocs.io/en/latest/Starting_with_GHDL.html
I got the gtkwave waveforms too.
Frank
Visitor lasplund
Please look at the VUnit documentation for both the get_compile_order and get_implementation_subset methods. Dependency means different things for compilation and elaboration
Visitor lasplund
create_dependency_graph is not part of the public API and should be avoided. What is your for the dependency information? Can it be solved with the public get_compile_order or get_implementation_subset methods?
