Observer gongdori
Cannot Find Cable!
Hi all,
I was trying to program the FPGA on ML605 V6 development board. When I tried to scan JTAG, I got a warning saying
"WARNING:iMPACT:923 - Cannot Find cable. Check cable setup!"
and got following results:
AutoDetecting cable. Please wait.
PROGRESS_START - Starting Operation.
Connecting to cable (Usb Port - USB21).
Checking cable driver.
 Driver file xusb_emb.sys found.
 Driver version: src=1029, dest=1029.
 Driver windrvr6.sys version = 10.2.1.0.Cable connection failed.
It looks that the PC saw usb-jtag, but it failed to connect to it.
Does anyone know why???
Thomas
Re: Cannot Find Cable!
Which Programmer do you have? - I recently found, the the newer ISE do not suppoer old (USB I) programmers anymore. (I had exactly the same message.)
But in your case it might be also something different.
Teacher eteam00
I'm using ISE 13.4 running on Windows Vista x64, and my USB Platform Cable (I) works fine.
-- Bob Elkind
SIGNATURE:
Summary:
Hm ... strange, I got that behaviour with two similar USB Programmers of the DG9 series trying to access the avnet S6 LX board.
When elaborating this, Impact came up with someting like "did not find USB II cable".
When trying to initialze the chain, sometimes "cable was not found", sometimes the jtag chain reports weired devices and device numbers. This happened with 13.2 and 13.3  (13.4 not tested anymore),
Without changing anything, neither SW / HW or board settings, everything worked fine just pluggin in DLS 10s.
Observer arash-rezaee
Hi Thomas
Did you find how to solve your problem? i have the same problem and I don`t know what to do. If you know the solution please let me know.
Arash
Newbie leeeeha
Did you find solution of your problem ? I have same problem.
Teacher rcingham
I had similar problem recently - ChipScopePro from ISE14.2 and Windows 7.
I tried Impact from ISE 12.2, which found the cable ok, since when no problems with the new ChipScopePro...
I blame Micro$0ft...
"If it don't work in simulation, it won't work on the board."
