Observer emounty
Error:iMPACT:2204
A search for this error message yields no results. Has anyone else encountered this before? Here's a suggestion for xilinx: When a tool developer writes code to print out an error codehow about adding an explanatory message to this search database? Just a thought.
Observer emounty
Re: Error:iMPACT:2204
Detailed content? There's an error code for Pete's sake. You tell me what the code means as I can't find an error message listing anywhere.
Well here's the solution found by a customer through trial and error.
Open the download.cmd file on the project tab.On the "assignfile" and "program" lines the argumentto the -p switch was 5 for some mysterious reason. There is only one device in the JTAG chain so changing the argument to 1 makes the download bitstream command work without error.
If I seem a little hostile it's because I have spent 80% of my time trying to get this tool to work rather than actual development work.   Now I have to try and figure out why I can't see my code in gdb.
Could you please provide the detailed content of the error message? This might give us some clues.
Observer emounty
Visitor cimasys
I, too, tire of error codes that have no meaning.  Especially when all they do is link to a xilinx search that comes up empty.
My probelm was exactly the same "-p 5" should have been "-p 1" in download.cmd.  Thanks for the fix - would have wasted a few hours on this one.
Observer ramonal
Hey,
I followed the instruction to change -p . In my case I had -p 3 and I changed it to 1 but I also get the ERRE:iMPACT:2204 - Can only assign file to device 1.
If anyone has an idea, I would be very grateful,
Ramona
Visitor morsub4u
I had the SAME problem!  There were two lines in my file that had "-p 5" and after changing them both, it works great.  Thanks for the help!!
Newbie u61971
Thank you.
I too was having this problem.
Visitor vorm153
I dont find download.cmd file. Can you tell me where it is?
