Visitor bharat1992
Error in getting ODDR output on ILA
[DRC REQP-1884] ODDR_has_invalid_load: ODDR cell ODDR_INST loads should only be an output buffer or a port, but it is driving an invalid load (one or more of): out_OBUF[0]_inst, u_ila_0/inst/ila_core_inst/shifted_data_in_reg[7][0]_srl8, and u_ila_0/inst/ila_core_inst/u_trig/U_TM/N_DDR_MODE.G_NMU[0].U_M/allx_typeA_match_detection.ltlib_v1_0_0_allx_typeA_inst/probeDelay1[0]_i_1
Scholar markcurry
Re: Error in getting ODDR output on ILA
You can only use ILA's on "internal" FPGA signals.  The output of an ODDR cell is a top-level IO, and not able to be probed by an ILA.
Mark
回复: Error in getting ODDR output on ILA
As said in the message, the ODDR output can only directly drive output port. It cannot drive fabric.
If you want to probe the output signal, you may consider adding ODDR input to ILA probe port.
Visitor bharat1192
But there must be some way to probe ODDR data
Visitor bharat1192
I added ODDR input to ILA but I am getting the same error again.
Can you please let me know some other ways of doing this .
Hi, @bharat1992 ,
Does the detailed information of the error message change?
Please confirm the connection bwtween ODDR/Q and ILA is removed.
