Visitor sarman_1998
How to change name of XADC channels in hardware manager?
Hi All,
  I'm using the XADC in a project and it would be really helpful if i could change the names of the channels as they appear in the Hardware Manager XADC window.  Is there a way to do this?
Also, it would be a really cool feature if you could enter a simple equation to be applied to readings.  This would allow the readings to be easily read if there is a voltage divider or some other device involved.
Eric
Re: How to change name of XADC channels in hardware manager?
Hi @sarman_1998,
Do you mean changing the names such as Temp, VCCINT, VCCAUX as in the image below:
That unfortunately is not possible. Those are properties of the XADC and you can't change the names.
About the equations for readings, you can individually get the values (in decimal) for each property via TCL, and then use the TCL expr command to perform math on it.
As an example, below is a command to get a list of all the existent XADC properties:
report_property [lindex [get_hw_sysmons] 0]
Property                       Type    Read-only  Value
ADC_GAIN                       hex     true       0128
ADC_OFFSET                     hex     true       0141
ALARM_OT_LOWER                 string  false      -273.1
ALARM_OT_LOWER_SCALE           enum    false      CELSIUS
ALARM_OT_UPPER                 string  false      -273.1
ALARM_OT_UPPER_SCALE           enum    false      CELSIUS
ALARM_TEMPERATURE_LOWER        string  false      -280.2
ALARM_TEMPERATURE_LOWER_SCALE  enum    false      CELSIUS
ALARM_TEMPERATURE_UPPER        string  false      -280.2
ALARM_TEMPERATURE_UPPER_SCALE  enum    false      CELSIUS
ALARM_VCCAUX_LOWER             string  false      0.000
ALARM_VCCAUX_UPPER             string  false      0.000
ALARM_VCCBRAM_LOWER            string  false      0.000
ALARM_VCCBRAM_UPPER            string  false      0.000
ALARM_VCCINT_LOWER             string  false      0.000
ALARM_VCCINT_UPPER             string  false      0.000
ALARM_VCC_PSAUX_LOWER          string  true       0.000
ALARM_VCC_PSAUX_UPPER          string  true       0.000
ALARM_VCC_PSINTFP_LOWER        string  true       0.000
ALARM_VCC_PSINTFP_UPPER        string  true       0.000
ALARM_VCC_PSINTLP_LOWER        string  true       0.000
ALARM_VCC_PSINTLP_UPPER        string  true       0.000
ALARM_VUSER0_LOWER             string  false      0.000
ALARM_VUSER0_UPPER             string  false      0.000
ALARM_VUSER1_LOWER             string  false      0.000
ALARM_VUSER1_UPPER             string  false      0.000
ALARM_VUSER2_LOWER             string  false      0.000
ALARM_VUSER2_UPPER             string  false      0.000
ALARM_VUSER3_LOWER             string  false      0.000
ALARM_VUSER3_UPPER             string  false      0.000
CLASS                          string  true       hw_sysmon
CONFIG_REG.ACQ                 binary  false      0
CONFIG_REG.ALM0                binary  false      0
CONFIG_REG.ALM1                binary  false      0
CONFIG_REG.ALM2                binary  false      0
CONFIG_REG.ALM3                binary  false      0
CONFIG_REG.ALM4                binary  false      0
CONFIG_REG.ALM5                binary  false      0
CONFIG_REG.ALM6                binary  false      0
CONFIG_REG.ALM8                binary  false      0
CONFIG_REG.ALM9                binary  false      0
CONFIG_REG.ALM10               binary  false      0
CONFIG_REG.ALM11               binary  false      0
CONFIG_REG.AVG                 binary  false      00
CONFIG_REG.BU                  binary  false      0
CONFIG_REG.CAL0                binary  false      0
CONFIG_REG.CAL2                binary  false      0
CONFIG_REG.CAL3                binary  false      0
CONFIG_REG.CAVG                binary  false      0
CONFIG_REG.CD                  binary  false      00000000
CONFIG_REG.CH                  binary  false      000000
CONFIG_REG.DUAL_EOS            binary  false      00
CONFIG_REG.DUAL_SEQ            binary  false      00
CONFIG_REG.EC                  binary  false      0
CONFIG_REG.I2C_A               binary  false      0000000
CONFIG_REG.I2C_EN              binary  false      0
CONFIG_REG.I2C_OR              binary  false      0
CONFIG_REG.MUX                 binary  false      0
CONFIG_REG.OT                  binary  false      0
CONFIG_REG.PMBUS_HRIO          binary  false      0000
CONFIG_REG.SEQ                 binary  false      0000
DESCRIPTION                    string  true       SysMon
ENABLE_ALL_AUXILIARY_CHANNELS  bool    false      0
FLAG.ALM0                      binary  true       0
FLAG.ALM1                      binary  true       0
FLAG.ALM2                      binary  true       0
FLAG.ALM3                      binary  true       0
FLAG.ALM4                      binary  true       0
FLAG.ALM5                      binary  true       0
FLAG.ALM6                      binary  true       0
FLAG.ALM8                      binary  true       0
FLAG.ALM9                      binary  true       0
FLAG.ALM10                     binary  true       0
FLAG.ALM11                     binary  true       0
FLAG.JTGD                      binary  true       0
FLAG.JTGR                      binary  true       0
FLAG.OT                        binary  true       0
FLAG.REF                       binary  true       1
I2C_ADDR_MEAS                  binary  true       0000000010101111
MAX_TEMPERATURE                string  true       29.4
MAX_TEMPERATURE_SCALE          enum    false      CELSIUS
MAX_VCCAUX                     string  true       1.787
MAX_VCCBRAM                    string  true       0.847
MAX_VCCINT                     string  true       0.844
MAX_VCC_PSAUX                  string  true       1.816
MAX_VCC_PSINTFP                string  true       0.847
MAX_VCC_PSINTLP                string  true       0.850
MAX_VUSER0                     string  true       0.000
MAX_VUSER1                     string  true       0.000
MAX_VUSER2                     string  true       0.000
MAX_VUSER3                     string  true       0.000
MIN_TEMPERATURE                string  true       22.5
MIN_TEMPERATURE_SCALE          enum    false      CELSIUS
MIN_VCCAUX                     string  true       1.778
MIN_VCCBRAM                    string  true       0.841
MIN_VCCINT                     string  true       0.841
MIN_VCC_PSAUX                  string  true       1.808
MIN_VCC_PSINTFP                string  true       0.844
MIN_VCC_PSINTLP                string  true       0.844
MIN_VUSER0                     string  true       2.997
MIN_VUSER1                     string  true       2.997
MIN_VUSER2                     string  true       2.997
MIN_VUSER3                     string  true       2.997
NAME                           string  true       localhost:3121/xilinx_tcf/Digilent/210308A1CBEB/xczu9_0/SYSMON
OT_AUTOMATIC_SHUTDOWN          binary  false      0000
SEQUENCER.ACQ_AUX0             binary  false      0
SEQUENCER.ACQ_AUX1             binary  false      0
SEQUENCER.ACQ_AUX2             binary  false      0
SEQUENCER.ACQ_AUX3             binary  false      0
SEQUENCER.ACQ_AUX4             binary  false      0
SEQUENCER.ACQ_AUX5             binary  false      0
SEQUENCER.ACQ_AUX6             binary  false      0
SEQUENCER.ACQ_AUX7             binary  false      0
SEQUENCER.ACQ_AUX8             binary  false      0
SEQUENCER.ACQ_AUX9             binary  false      0
SEQUENCER.ACQ_AUX10            binary  false      0
SEQUENCER.ACQ_AUX11            binary  false      0
SEQUENCER.ACQ_AUX12            binary  false      0
SEQUENCER.ACQ_AUX13            binary  false      0
SEQUENCER.ACQ_AUX14            binary  false      0
SEQUENCER.ACQ_AUX15            binary  false      0
SEQUENCER.ACQ_USER0            binary  false      0
SEQUENCER.ACQ_USER1            binary  false      0
SEQUENCER.ACQ_USER2            binary  false      0
SEQUENCER.ACQ_USER3            binary  false      0
SEQUENCER.ACQ_VPVN             binary  false      0
SEQUENCER.AVG_AUX0             binary  false      0
SEQUENCER.AVG_AUX1             binary  false      0
SEQUENCER.AVG_AUX2             binary  false      0
SEQUENCER.AVG_AUX3             binary  false      0
SEQUENCER.AVG_AUX4             binary  false      0
SEQUENCER.AVG_AUX5             binary  false      0
SEQUENCER.AVG_AUX6             binary  false      0
SEQUENCER.AVG_AUX7             binary  false      0
SEQUENCER.AVG_AUX8             binary  false      0
SEQUENCER.AVG_AUX9             binary  false      0
SEQUENCER.AVG_AUX10            binary  false      0
SEQUENCER.AVG_AUX11            binary  false      0
SEQUENCER.AVG_AUX12            binary  false      0
SEQUENCER.AVG_AUX13            binary  false      0
SEQUENCER.AVG_AUX14            binary  false      0
SEQUENCER.AVG_AUX15            binary  false      0
SEQUENCER.AVG_AUX_AVG          binary  false      0
SEQUENCER.AVG_BRAM_AVG         binary  false      0
SEQUENCER.AVG_INT_AVG          binary  false      0
SEQUENCER.AVG_SYSMON_CAL       binary  false      0
SEQUENCER.AVG_TEMP             binary  false      0
SEQUENCER.AVG_USER0            binary  false      0
SEQUENCER.AVG_USER1            binary  false      0
SEQUENCER.AVG_USER2            binary  false      0
SEQUENCER.AVG_USER3            binary  false      0
SEQUENCER.AVG_VCC_PSAUX        binary  false      0
SEQUENCER.AVG_VCC_PSINTFP      binary  false      0
SEQUENCER.AVG_VCC_PSINTLP      binary  false      0
SEQUENCER.AVG_VPVN             binary  false      0
SEQUENCER.CHSEL_AUX0           binary  false      0
SEQUENCER.CHSEL_AUX1           binary  false      0
SEQUENCER.CHSEL_AUX2           binary  false      0
SEQUENCER.CHSEL_AUX3           binary  false      0
SEQUENCER.CHSEL_AUX4           binary  false      0
SEQUENCER.CHSEL_AUX5           binary  false      0
SEQUENCER.CHSEL_AUX6           binary  false      0
SEQUENCER.CHSEL_AUX7           binary  false      0
SEQUENCER.CHSEL_AUX8           binary  false      0
SEQUENCER.CHSEL_AUX9           binary  false      0
SEQUENCER.CHSEL_AUX10          binary  false      0
SEQUENCER.CHSEL_AUX11          binary  false      0
SEQUENCER.CHSEL_AUX12          binary  false      0
SEQUENCER.CHSEL_AUX13          binary  false      0
SEQUENCER.CHSEL_AUX14          binary  false      0
SEQUENCER.CHSEL_AUX15          binary  false      0
SEQUENCER.CHSEL_AUX_AVG        binary  false      0
SEQUENCER.CHSEL_BRAM_AVG       binary  false      0
SEQUENCER.CHSEL_INT_AVG        binary  false      0
SEQUENCER.CHSEL_SYSMON_CAL     binary  false      0
SEQUENCER.CHSEL_TEMP           binary  false      0
SEQUENCER.CHSEL_USER0          binary  false      0
SEQUENCER.CHSEL_USER1          binary  false      0
SEQUENCER.CHSEL_USER2          binary  false      0
SEQUENCER.CHSEL_USER3          binary  false      0
SEQUENCER.CHSEL_VCC_PSAUX      binary  false      0
SEQUENCER.CHSEL_VCC_PSINTFP    binary  false      0
SEQUENCER.CHSEL_VCC_PSINTLP    binary  false      0
SEQUENCER.CHSEL_VPVN           binary  false      0
SEQUENCER.CHSEL_VREFN          binary  false      0
SEQUENCER.CHSEL_VREFP          binary  false      0
SEQUENCER.DUAL_AUX0            binary  false      0
SEQUENCER.DUAL_AUX1            binary  false      0
SEQUENCER.DUAL_AUX2            binary  false      0
SEQUENCER.DUAL_AUX3            binary  false      0
SEQUENCER.DUAL_AUX4            binary  false      0
SEQUENCER.DUAL_AUX5            binary  false      0
SEQUENCER.DUAL_AUX6            binary  false      0
SEQUENCER.DUAL_AUX7            binary  false      0
SEQUENCER.DUAL_AUX8            binary  false      0
SEQUENCER.DUAL_AUX9            binary  false      0
SEQUENCER.DUAL_AUX10           binary  false      0
SEQUENCER.DUAL_AUX11           binary  false      0
SEQUENCER.DUAL_AUX12           binary  false      0
SEQUENCER.DUAL_AUX13           binary  false      0
SEQUENCER.DUAL_AUX14           binary  false      0
SEQUENCER.DUAL_AUX15           binary  false      0
SEQUENCER.DUAL_AUX_AVG         binary  false      0
SEQUENCER.DUAL_BRAM_AVG        binary  false      0
SEQUENCER.DUAL_INT_AVG         binary  false      0
SEQUENCER.DUAL_SYSMON_CAL      binary  false      0
SEQUENCER.DUAL_TEMP            binary  false      0
SEQUENCER.DUAL_USER0           binary  false      0
SEQUENCER.DUAL_USER1           binary  false      0
SEQUENCER.DUAL_USER2           binary  false      0
SEQUENCER.DUAL_USER3           binary  false      0
SEQUENCER.DUAL_VPVN            binary  false      0
SEQUENCER.DUAL_VREFN           binary  false      0
SEQUENCER.DUAL_VREFP           binary  false      0
SEQUENCER.INSEL_AUX0           binary  false      0
SEQUENCER.INSEL_AUX1           binary  false      0
SEQUENCER.INSEL_AUX2           binary  false      0
SEQUENCER.INSEL_AUX3           binary  false      0
SEQUENCER.INSEL_AUX4           binary  false      0
SEQUENCER.INSEL_AUX5           binary  false      0
SEQUENCER.INSEL_AUX6           binary  false      0
SEQUENCER.INSEL_AUX7           binary  false      0
SEQUENCER.INSEL_AUX8           binary  false      0
SEQUENCER.INSEL_AUX9           binary  false      0
SEQUENCER.INSEL_AUX10          binary  false      0
SEQUENCER.INSEL_AUX11          binary  false      0
SEQUENCER.INSEL_AUX12          binary  false      0
SEQUENCER.INSEL_AUX13          binary  false      0
SEQUENCER.INSEL_AUX14          binary  false      0
SEQUENCER.INSEL_AUX15          binary  false      0
SEQUENCER.INSEL_USER0          binary  false      0
SEQUENCER.INSEL_USER1          binary  false      0
SEQUENCER.INSEL_USER2          binary  false      0
SEQUENCER.INSEL_USER3          binary  false      0
SEQUENCER.INSEL_VPVN           binary  false      0
SUPPLY_OFFSET                  hex     true       0135
SYSMON_REFRESH_RATE_MS         int     false      1000
TEMPERATURE                    string  true       28.4
VAUXP0_VAUXN0                  string  true       0.000
VAUXP1_VAUXN1                  string  true       0.000
VAUXP2_VAUXN2                  string  true       0.000
VAUXP3_VAUXN3                  string  true       0.000
VAUXP4_VAUXN4                  string  true       0.000
VAUXP5_VAUXN5                  string  true       0.000
VAUXP6_VAUXN6                  string  true       0.000
VAUXP7_VAUXN7                  string  true       0.000
VAUXP8_VAUXN8                  string  true       0.000
VAUXP9_VAUXN9                  string  true       0.000
VAUXP10_VAUXN10                string  true       0.000
VAUXP11_VAUXN11                string  true       0.000
VAUXP12_VAUXN12                string  true       0.000
VAUXP13_VAUXN13                string  true       0.000
VAUXP14_VAUXN14                string  true       0.000
VAUXP15_VAUXN15                string  true       0.000
VCCAUX                         string  true       1.781
VCCBRAM                        string  true       0.844
VCC_PSAUX                      string  true       1.811
VCC_PSINTLP                    string  true       0.847
VP_VN                          string  true       0.002
VREFN                          string  true       0.000
VREFP                          string  true       0.000
lets say I'm interested in the values for VCCAUX. I can use the following command. Observe TCL returned me the value in Volts.
get_property VCCAUX [lindex [get_hw_sysmons] 0]
1.781
to perform calculations, I can actually store the value above into a variable, as below. And to read the value stored in that variable, I can use the $var_name:
set my_var [get_property VCCAUX [lindex [get_hw_sysmons] 0]]
1.781
$my_var
[1.781]
Now, I can do math with that variable using the command expr:
expr {$my_var * 2}
3.562
A list with all the possible math operations and examples in TCL is available here:
http://wiki.tcl.tk/583
I hope that helps.
Andre Guerrero
Product Applications Engineer
Hi @sarman_1998,
1.781
1.781
$my_var
[1.781]
expr {$my_var * 2}
3.562
I hope that helps.
Andre Guerrero
Visitor sarman_1998
  Adding the ability to rename those channels, either as a user defined "friendly name" in hardware manager, or in the IP wizard would be a great enhancement to Vivado.  I have seen other IP blocks that have a port renaming tab i wonder if that could be added to the XADC wizard?
Also, at least up to version 2018.1, i've noticed that in hardware manager, the Y axis of the graph for voltages won't go above 0.5V.  I understand that in one mode the XADC reads +- 0.5V but i'm using the mode that reads 0-1.0V.  It would be great if the Y axis would at least scale up to 1.0V or if the Y axis min/max could be set in hardware manager.
  Eric
