Participant sulilittle
How to verify results without Chipscope?
Now,because of the maximum speed of Bram exceeds the limited speed,I can not perceive the waveform by Chipscope,what should I do?Thank you very much!
Instructor
Instructor
Re: How to verify results without Chipscope?
One thing you could do is to use a 1/2 speed clock for ChipScope and take the signals of interest
from your original clock domain to the 1/2 speed domain by alternately clocking them into two
registers (odd clock cycles in one register, even in the other) so that the ChipScope data is twice
as wide but running at half the original clock rate.
-- Gabor
-- Gabor
hi,
     you have two options
     1. either u check your design with the ISIM simulator which will be a behavioural simulation
     2.  you can check your design with a logic analyser of agilent technologies physically.
best regards
Chandra
Best Regards
Chandrajit
