ILA window not opening after I program the device
Hi, I set up the ILA debug  after synthesis (using vivado 2016.1). I get no errors I generate bitstreams, I program the device, and refresh again. Why don't I see the debugger window or the trigger window?
log copy is below
Finished Writing Synthesis Report : Time (s): cpu = 00:00:34 ; elapsed = 00:00:45 . Memory (MB): peak = 610.809 ; gain = 400.539
Synthesis finished with 0 errors, 0 critical warnings and 2 warnings.
Synthesis Optimization Runtime : Time (s): cpu = 00:00:18 ; elapsed = 00:00:24 . Memory (MB): peak = 610.809 ; gain = 139.746
Synthesis Optimization Complete : Time (s): cpu = 00:00:34 ; elapsed = 00:00:45 . Memory (MB): peak = 610.809 ; gain = 400.539
INFO: [Project 1-571] Translating synthesized netlist
INFO: [Project 1-570] Preparing netlist for logic optimization
INFO: [Opt 31-138] Pushed 0 inverter(s) to 0 load pin(s).
INFO: [Project 1-111] Unisim Transformation Summary:
No Unisim elements were transformed.
INFO: [Common 17-83] Releasing license: Synthesis
30 Infos, 9 Warnings, 0 Critical Warnings and 0 Errors encountered.
synth_design completed successfully
synth_design: Time (s): cpu = 00:00:31 ; elapsed = 00:00:34 . Memory (MB): peak = 634.977 ; gain = 404.422
INFO: [Common 17-1381] The checkpoint 'E:/ the_mission/level_2/V2/V2.runs/synth_1/Top_design_wrapper.dcp' has been generated.
report_utilization: Time (s): cpu = 00:00:00 ; elapsed = 00:00:00.016 . Memory (MB): peak = 634.977 ; gain = 0.000
INFO: [Common 17-206] Exiting Vivado at Thu Aug 09 16:14:52 2018...
Re: ILA window not opening after I program the device
Hi @benaka,
That is a log just for the synthesis.
After you open HW Manager and program the board, could you verify if any message/warning is shown in the console?
Is suspect the ILA (or its clock) is not being found, so the visualization is not initialized.
In addition, what is the device that you are using?
Andre Guerrero
Product Applications Engineer
Hi @benaka,
Any updates on this case? Please let us know if you were able to fix it or if you still need help.
Thanks!
Andre Guerrero
I was able to get it working.
Thank you for the support.
