Observer sumita1981
Real Radix Setting reset in Vivado 2016.1, 2016.2, 2016.3 Hardware Manager
From Vivado 2016.1, when you select radix setting to "Real" in ILA waveform window of Hardware Manager, the setting resets every time ila is triggered.
This issue doesn't happen in Vivado 2015.4 and earlier.
And I'm very suprised and disappointed as this easy bug still exists in Vivado 2016.3.
When do you plan to fix this?
Is it possible to release patches prior to 2016.4 release?
Re: Real Radix Setting reset in Vivado 2016.1, 2016.2, 2016.3 Hardware Manager
Hi @sumita1981,
Thanks for sharing this info. I filed a CR-963037. This issue will be addressed in future version of Vivado.
Arpan
Hi @sumita1981,
Arpan
Observer sumita1981
Hi @arpansur,
Thank you for your reply.
Also real radix settings aren't applied to exported csv file, but ok to native format data.
I hope both will be fixed soon!
Noriaki
Visitor bobsakamoto
I just tried setting the radix to real fixed point signed Binary Point 12 in Vivado 2016.4.  When ILA is retriggered, it reverts the setting back to hexadecimal.  It is more convenient for me to keep working in Vivado 2015.4 rather than having to mess with the Binary Point settings every time I trigger the ILA
Visitor bobsakamoto
  I tried Vivado 2017.1 and it still resets the radix when th eILA is retriggered..
   Also, when I tried Analog Settings Y Range Fixed, it appeared broken and when I tried to use it I got an exception.
regards
Visitor bobsakamoto
Just tried 2017.2 and still the same thing.  I guess Xilinx is not interested in solving the situation.
I am also experiencing this problem and it is a huge nuisance.  I am surprised and disappointed to hear that it has been around since 2016.1!  Xilinx - please correct it in 2017.3.
Same thing in 2017.4 Is there any workaround available?
Visitor me_sur
just encountered this issue in 2017.4.
This is tragicomic.
Hi All,
There's no workaround for this issue yet. This feature was borrowed from the Simulation waveform engine, and that's what ultimately was causing the issue with the debug engine.
There was no simple solution other than to rebuild the whole feature, so that's what is being done at the moment. In addition, if you look into Vivado 2018.X, you'll see that the feature has been removed. It should reintroduced without bugs in the 2019 Vivado version.
I wanted to communicate to our Customers that we have heard the complaints and are working on fixing it. I also apologize for this issue and for not having a workaround at the moment.
Andre Guerrero
Product Applications Engineer
