Visitor pilakkat
Vivado 2013.4 : Adding ILA inside a BD causes ILA(s) to fail
I am having this strange problem with adding subsystem BD's with ILA cores.
Trying to add a BD block as a subsystem to the ADI's FMMCOMMS2 Reference design, causes the already existing ILA and also the newly added ILA to fail. The hardware manager is able to connect, but trying to run the immediate trigger results in no apparent action and no error is reported!
Doubts the problem may be related to the clock and clock constraints used inside the subsystem BD which is also used as the ILA clock. Is there any specific care to be taken when adding a clock port to a BD?
Scholar dwisehart
Re: Vivado 2013.4 : Adding ILA inside a BD causes ILA(s) to fail
Run the timing report.  Are any timing errors reported?  Run the clock internation report.  Are their clock interactions that are not constrained?  It sounds like a cross clock domain problem.
Daniel
