Vivado 2016.2 Crashes with Pure Virtual Function Call
I am using Vivado 2016.2 in batch mode and Vivado keeps crashing with "Pure Virtual Function Call" error messages. When this error message appears, the typical last messages are as follows:
1.
Start Applying 'set_property' XDC Constraints
 or
2.
INFO: [Synth 8-5580] Multithreading enabled for synth_design using a maximum of 2 processes.
I am using Windows Server 2012 R2.
Also, if I reboot the system, the first run will usually go through with no problem, but all subsequent runs will fail. Does anyone knows anything I might help with this issue?
Thank you.
Peter Chen
Re: Vivado 2016.2 Crashes with Pure Virtual Function Call
Hi @avt_peter_chen,
If the Vivado 2016.2 installed machine does not have supported OS for this Vivado version, than this might be the root cause of this type of crash. Check the supported OS for Vivado 2016.2 mentioned in the below link.
https://www.xilinx.com/support/answers/54242.html
hemangd
hemangd
Hi @avt_peter_chen,
hemangd
hemangd
Hi @hemangd,
Thank you for your response.
From the link I see that none of the windows server os is supported. Does this mean windows server os should not be used and will not be supported by the design tools?
Also, from my experience, the build does work right after a system reboot. The build only start failing after a build has been completed. This suggests that the tool should work on the os.
Peter Chen
Hi @avt_peter_chen,
It might work with Windows server 2012 OS but Xilinx recommend to use the OS what are suggested in that AR. Because Vivado is fully tested and verified with those OS.
hemangd
hemangd
Hi @hemangd,
Okay, I will give it a try.
Peter Chen
Hi ,
Sure you can try.
Once your issue resolves, make sure you close this thread by marking as accepted solution.
hemangd
hemangd
