Participant sparky989
Vivado 2018.1 ILA Advanced Trigger - TSM Syntax for Counters
I'm getting syntax errors in a Trigger State Machine script using the counters concerning conflicting matches on counters.
Here's an example.
  • [Labtools 27-2066] Counter $COUNTER0 has a conflicting match value ==16'u0997 with previously defined value ==16'u0100 in . [V:/opt_cam_intf_top/opt_cam_intf_top.srcs/constrs_1/new/ultra_vjitter_advanced_logic_anal_trigger.tsm:403]
See the attached complete errors.tif file, and the attached TSM file.
Any idea what's wrong?
Re: Vivado 2018.1 ILA Advanced Trigger - TSM Syntax for Counters
The problem was that as stated in ug908 under counter conditions that "Each counter has only one counter comparator.  This measn that you can only use a prticular counter in a counter condition once in the entire trigger state machine.".
I had 4 counter comparisons so I had to create 4 counters that reset and count at the same times and use a different one for each unique count comparison.
