Visitor mhuebner_hbp
Where can I find libPortabilityNOSH.dll?
Hi forum,
I have replaced my laptop which I use to program Spartan 3E devices in the field by a new device running under Windows 10 Pro.
The software that I have installed is Xilinx ISE DS 14.7.
The application that I want to use is IMPACT.
The problem is that IMPACT is crashing everytime I start the browser in order to open or store a project. This behaviour is described already and a resolution can be found in the database under AR# 62380
Unfortunately this resolution does not work for me, because there is no libPortabilityNOSH.dll in my Xilinx installation directory.
Any idea, where I can get this DLL from?
Thanks in advance & regards
Michael
Re: Where can I find libPortabilityNOSH.dll?
Hi @mhuebner_hbp
You will find this file in the following location of your installation directory: <install_path>\Xilinx\14.7\ISE_DS\ISE\lib\nt64\
and <install_path>\Xilinx\14.7\ISE_DS\common\lib\nt64\
Vinay
Tags (2)
Hi @mhuebner_hbp
Vinay
Hi anm and Vinay,
it works now. I searched only in <install_path>\Xilinx\14.7\ISE_DS\common\lib\nt64\
But this directory contained only the libPortability.dll library, not the NOSH version. But Vinay is right, there is a copy of libPortabilityNOSH.dll in the directory <install_path>\Xilinx\14.7\ISE_DS\ISE\lib\nt64\
Thanks to you both.
Michael
