Observer khal
iMPACT in ISE 14.7 (for Windows 10)
Does iMPACT in the new VM ISE 14.7 (for Windows 10) solution only support programming of Spartan-6 devices?
If I create a programming chain involving multiple XCF32 platform flash devices, would I be able to select MCS files for a Virtex-5 and still use the version of iMPACT which comes with this solution? I understand that this VM solution is only supposed to support Spartan-6, but was curious if this was just from a synthesis and place and route standpoint.
Just trying to figure out a method by which I can program legacy boards which use Virtex-5 and Platform Flash devices in Windows 10.
Re: iMPACT in ISE 14.7 (for Windows 10)
Hi @khal
As ug1227-spartan6-vm-windows10.pdf (Page 5) only Spartan 6 devices are supported by VM ISE 14.7 (for Windows 10)
Instead of using VM ISE 14.7 (for Windows 10); you can use ISE 14.7 (64-bit) with changes specified in AR#62380.
Bhushan
Bhushan
