vivado 2015.3 on Windows10
Dear Forum
I installed vivado on Win8.1 and, for my simple application, all was good.
Now I update to win10. When start the -Syntesis- i get error licence:
[common 17-345]
Some suggestion
Re: vivado 2015.3 on Windows10
[ Edited ]
Hi @rob69
Share the output of tcl command: report_environment -file env.txt
Share the generated env.txt file here.
Vinay
[ Edited ]
Vivado 2015.3 is not supported on Windows 10
Use one of the supported OS from the below link
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_3/ug973-vivado-release-notes-install-license.pdf
Satish
Refer to these threads for similar discussion:
https://forums.xilinx.com/t5/Installation-and-Licensing/Windows-10/m-p/645652/highlight/true#M12388
https://forums.xilinx.com/t5/General-Technical-Discussion/status-of-windows-10-amp-Vivado-2015-2/m-p/645942/highlight/true#M35028
Accept as solution if it resolved your query, give kudos(star on left) if it led you to the solution.
Nupur
Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark).
