Observer tuan.nhanh
[zcu104] application on RPU not print on terminal
I made a bootloader for sdcard and it just runs a simple application on RPU that  print "hello" on terminal.
But when deploying that sdcard, I see nothing on terminal.
But if the app run on APU, i can see the output in terminal.
So what is the problem and how to solve it.
Re: [zcu104] application on RPU not print on terminal
Hi @tuan.nhanh ,
From bif file, I'm assuming you have created fsbl application for RPU but destination CPU is APU while creating boot image. Please make sure destination CPU is correct.
Please refer UG1209(v2018.3), page no.68 for SD boot sequence where application is executing on RPU.
Thanks & Regards
Anil B
Hi @tuan.nhanh ,
How have you created the boot image for sd card? what is your bif file?
Do you see any error messages?
Thanks & Regards
Anil B
Observer tuan.nhanh
@abommera
Thank you.
I created a zcu104 FSBL and then choose Xilinx -> Create Boot Image from Xilinx SDK to create boot.bin.
There is nothing on Terminal.
Hi @tuan.nhanh ,
Have you set the sd boot mode using SW6[4:1] (OFF,OFF,OFF,ON)? Can you please share your bif file?
If still not works, can you try with pre-built images for zcu104?
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842543/Zynq+2018.2+Release?f=print
Thanks & Regards
Anil B
Observer tuan.nhanh
@abommera
My application is standalone and I used baremetal.
I attached my bif image.
SW6[4:1] (OFF,OFF,OFF,ON)? => Yes I did. If I choose APU, I can see log on terminal but if I choose RPU, I see nothing.
Best regards
Hi @tuan.nhanh ,
Thanks & Regards
Anil B
Observer tuan.nhanh
@abommera
Thank you very much for your note.
I had 2 elfs:
- an app run on APU (.elf) coded by me.
- an app run on RPU (.elf).This file I got from another project => this must run  before my app.
- a FPGA (.bit) from another project.
So when creating fsbl, should I create APU FSBL or RPU FSBL?
Observer tuan.nhanh
@abommera
Hi, please ignore the previous question since I can make it work.
But i faced another problem:
- The elf on RPU is running.
- The elf on APU is running, but it always reset the APU code. So what should I config to fix this (such as stack, heap, ...)
Found that it is problem of memset. App reset when calling memset. So why? (I used baremetal)
fixed all
