Participant jarios86
AXI DMA test errors on Petalinux
Hi everyone,
I'm trying to use the axi_dma xilinx driver in order to make transfer between PS and PL in both way. I'm trying several modules that I found on the web (i.e dma_proxy) but no one works, so I want to start form the begining, testing the module axidmatest from xilinx.
I'm using Vivado 2016.3 and petalinux 2016.4 with the kernel 4.6. I have created a basic design for axidma loopback, connection de mm2s_int and s2mm_int to the PS.I have configured my kernel (petalinux-config -c kernel) to enable the axi dma engine and the axidmatest module.
I followed the xilinx.wiki in order to use the axidma module but I see some difference and if I change some parameters I get different results. This is my device_tree in the pl.dtsi file:
pl device tree
Differences between my device tree and the xilinx wiki device tree are interruptions numbers and one aditional line. The wiki version has interruptions as follow:
On the top: interrupts = <0 29 4 0 30 4>;
MM2S: interrupts = <0 29 4>;
S2MM: interrupts = <0 30 4>;
The aditional line is "xlnx,include-dre ;" that is include after "xlnx,device-id = <0x0>;" in both channel, mm2s and s2mm.
When I boot my system I get the follow message:
xilinx-vdma 40400000.dma: Xilinx AXI VDMA Engine Driver Probed!!
But the axidmates doesn't work.
If I change my device tree in order to be exactly than wiki device tree, I get time out error:
dma1chan0-dma1c: #0: tx test timed out
dma1chan0-dma1c: #1: tx test timed out
dma1chan0-dma1c: #2: tx test timed out
dma1chan0-dma1c: #3: tx test timed out
dma1chan0-dma1c: #4: tx test timed out
If I don't change my device tree interruption mapping (only adding axidmatest block), I get many errors. Attached you can finde the log file.
Any idea?? I have looked for across the wev but I cannot be able to manage the axidma engine.
Thanks in advance
Best
Re: AXI DMA test errors on Petalinux
I solved this problem as I explain in the next link:
https://forums.xilinx.com/t5/Embedded-Linux/AXIDMA-test-issue/m-p/798214#M22092
Best,
Antonio
I'm using Zynq7100 MMP platform from AVNET.
Any help?? I think the problem could be related on the configuration, but I have checked everything and I don't know what I'm doing wrong.
I changed the version of both software in order to be the same. Now I use Vivado 206.3 and Petalinux 2016.3, but the problem persists.
Please, any help??
Best
Visitor kolpaland
I had the same problem, i tried dma_proxy driver with axi_dma.
It doesn't work because of linux kernel sources, give a look to change history of https://github.com/Xilinx/linux-xlnx/commits/master/drivers/dma/xilinx/xilinx_dma.c.
Developers delete AXI DMA driver! So just don't use latest version of linux, try version xilinx-v2016.2 for example https://github.com/Xilinx/linux-xlnx/tree/xilinx-v2016.2
Best,
Antonio
