Scholar beandigital
AXI Lite Read
I have a developed my own AXI Lite IP and I am having some problems with read transactions. I have a Microblaze which I am using to do two reads. The first read completes fine but the second doesnt. I can see in simulation that the arvalid signal never goes high on the second. Although if I look at the AXI Lite Bus it seems to be setting this signal but not passing it onto my IP. I am a bit puzzled as to why the first should be ok but the second never start.
TIA
Jon
Re: AXI Lite Read
If you used the create IP wizard that includes the axi ipif, my first guess is that you are not releasing IP2Bus_RdAck when Bus2IP_RdCE goes inactive. If you hold IP2Bus_RdAck active for another clock edge after rdce deasserts, you can cause problems.
Scholar beandigital
Re: AXI Lite Read
I actually created my own IP without using the wizard. The problem was that Iforgot to add the PROTOCOL parameter in the MPD file. I can only assume that the AXI bus thought that my IP was a AXI instead of AXI Lite.
