AXI Quad SPI:no sck signal output
Hello everyone,I use AXI Quad SPI v3.2 in Block Design with the Kintex7-2 device.The configuration of the SPI is:
I have noted this :
So the core is configured with Frequency Ratio set to 2 and the AXI is configured to operate at 100 MHz). the ext_spi_clk is 80MHz.But I found no  sck signal  output.
I am using VIVADO 2017.2 on Windows7.
回复: AXI Quad SPI:no sck signal output
I have solved it.
I found that when configure Microblaze without check 'Use Instruction and Data Caches',it will work normally.
But I don't konw why.
I have solved it.
