AXI UART and IO Module
using Vivado 2015.2 and KC705 board.
I have a Block Design  with a Microblaze where there is a AXI UARTlite for the UART and I want to use the IOModule as a parrallel  interface to talk to a non-axi logic.
I have generated the address map and have notice an issue with the UART. When looking in the disassembly window i noticed that when writing to the UART it is going to the base address in the IO Module. Even though i'm not usng the UART in the IO Module.
are there any issues with using IO Module with MB.
How can i set it up to use base address of the AXI UartLITE
Could you please share the block design as I doubt about the connections you made?
Praveen
