Asynchronous FSL
Tools used: ISE 9.2.3 EDK 9.2
I am trying to create a Microblaze system using Asynchronous FSL cores.  The Microblaze is running at 100MHz and the cores are running at 125MHz.  I am also debugging with SDK/XMD and Chipscope Pro on one of the FSL cores.
BEGIN fsl_v20
 PARAMETER INSTANCE = fslreg_access_0_to_microblaze_0_0
 PARAMETER HW_VER = 2.11.a
 PARAMETER C_ASYNC_CLKS = 1
 PARAMETER C_READ_CLOCK_PERIOD = 8000
 PARAMETER C_IMPL_STYLE = 1
 PARAMETER C_FSL_DEPTH = 512
 PORT SYS_Rst = sys_bus_reset
 PORT FSL_M_Clk = fsl_clk_s
 PORT FSL_S_Clk = sys_clk_s
END
BEGIN fslreg_access
 PARAMETER HW_VER = 1.00.a
 BUS_INTERFACE MFSL = fslreg_access_0_to_microblaze_0_0
 BUS_INTERFACE SFSL = microblaze_0_to_fslreg_access_0_0
 PORT FSL_Clk = sys_clk_s
 PORT REG_Write = REG_Write
 PORT REG_DataOut = REG_DataOut
 PORT REG_DataIn = REG_DataIn
 PORT REG_Address = REG_Address
 PORT DEBUG_Trigger = fslreg_access_0_DEBUG_Trigger_to_chipscope_ila_1
 PORT DEBUG_Data = fslreg_access_0_DEBUG_Data
 PORT REG_Clk = fsl_clk_s
END
BEGIN fsl_v20
 PARAMETER INSTANCE = microblaze_0_to_fslreg_access_0_0
 PORT FSL_S_Clk = fsl_clk_s
 PORT FSL_M_Clk = sys_clk_s
END
The parameters of the MSFL and SFSL cores are shown above.  I am not sure that this is the correct way to connect the clocks to the fsl_v20 cores or not.  I believe that the sys clock (100MHz) is correctly connected to the Microblaze side of the bus, and the fsl clock (125MHz) is connected to the fslreg_access side, but this configuration is not working anywhere near as reliably as the synchronous version was.
Is there any examples of an Asynchronous FSL system?  Google and Xilinx searches have failed me so far.
Steve
Message Edited by swhaworth on 10-29-2007 03:45 PM
Your connection looks correct.
Can you define "not reliable"?
Missing data, too many data, stuck,...?
Göran Bilski
