Newbie jp55
Automating SDK builds
I'm trying to create a build script for my C SDK project on windows.
I've checked here, but have been unable to find any help on building from the command line.
I then found this, and followed it's instructions, but it seems to just generate makefiles?  It doesnt actually create my .elf file.
(I created a .bat script version of it, and a .sh version run under cygwin.  The .sh version doesn't work, as it can't seem to find/use the java virtual machine on my windows computer)
So I've been thinking I can use that to generate a makefile for my project, and then call "make all" in cygwin to actually build the project and get my .elf file?
However this means I have to create symlinks so that the commands in the makefile call the right executables.  This seems like a messy way of doing things.
Am I going about this the right way, or are the commands described in the link supposed to actually build the project?
any help would be greatly appreciated
Re: Automating SDK builds
to go from XPS to SDK, you can use psf2edward command. See page 43:
http://www.xilinx.com/support/documentation/sw_man​uals/xilinx13_4/est_rm.pdf
To generate the application. You can use the appguru tool from command line. The appguru
will allow you to create the example designs (Hello_world, memory test, ect.) from the command line.
For help here, open an ISE shell and type appguru -help fro assistance using this.
Finally, to run libgen. again see the link above on page 87.
Hope this helps
