Base System Builder Error on ML505 Board
i used base system builder on ml505 board, when i select the Tri-Mode Ethernet MAC, at netlist generation xps gives an error message below,
Writing module to "hard_ethernet_mac_wrapper_async_fifo_v6_1_2.ngo"...
Loading design module
"D:\ISE_Design\calisma\bsb_design_creation\mlm505_bsb_design_own\implementation\
hard_ethernet_mac_wrapper\hard_ethernet_mac_wrapper_async_fifo_v6_1_2.ngo"...
ERROR:NgdBuild:76 - File
on\hard_ethernet_mac_wrapper\hard_ethernet_mac_wrapper_async_fifo_v6_1_2.ngo"
cannot be merged into block
"Hard_Ethernet_MAC/I_RX0/I_RX_TEMAC_IF/I_RX_CL_IF/I_RX_CLIENT_FIFO"
(TYPE="hard_ethernet_mac_wrapper_async_fifo_v6_1_2") because one or more pins
on the block, including pin "Dout<19>", were not found in the file. Please
make sure that all pins on the instantiated component match pins in the
lower-level design block (irrespective of case). If there are bussed pins on
this block, make sure that the upper-level and lower-level netlists use the
same bus-naming convention.
Executing edif2ngd -noa
hard_ethernet_mac_wrapper_async_fifo_v6_1_1.edn"
"hard_ethernet_mac_wrapper_async_fifo_v6_1_1.ngo"
Release 10.1.03 - edif2ngd K.39 (nt)
Copyright (c) 1995-2008 Xilinx, Inc. All rights reserved.
INFO:NgdBuild - Release 10.1.03 edif2ngd K.39 (nt)
INFO:NgdBuild - Copyright (c) 1995-2008 Xilinx, Inc. All rights reserved.
PMSPEC -- Overriding Xilinx file <D:/Xilinx/10.1/EDK/data/edif2ngd.pfd> with
local file <D:/Xilinx/10.1/ISE/data/edif2ngd.pfd>
Writing module to "hard_ethernet_mac_wrapper_async_fifo_v6_1_1.ngo"...
hard_ethernet_mac_wrapper\hard_ethernet_mac_wrapper_async_fifo_v6_1_1.ngo"...
on\hard_ethernet_mac_wrapper\hard_ethernet_mac_wrapper_async_fifo_v6_1_1.ngo"
"Hard_Ethernet_MAC/I_TX0/I_TX_TEMAC_IF/I_TX_CL_IF/I_TX_CLIENT_FIFO"
(TYPE="hard_ethernet_mac_wrapper_async_fifo_v6_1_1") because one or more pins
on the block, including pin "Wr_count<3>", were not found in the file.
Please make sure that all pins on the instantiated component match pins in
the lower-level design block (irrespective of case). If there are bussed
pins on this block, make sure that the upper-level and lower-level netlists
use the same bus-naming convention.
i also download base system builder application
http://www.xilinx.com/products/boards/ml505/ml505_10.1_3_1/docs/ml505_bsb_design_creation.pdf
unfortunately i got the same error.
