Boot on parallel flash is longer than Spi flash
I'm working on Xilin Spartan 3A starter board and I try to send and receive udp packet. And I want to program flash xith this code
When I program Nor flash (parallel flash) the program takes about 3 minutes before start while when run on spi flash (serial flash) it takes 11 seconds before start
I don't understand why it's longer to run on parallel flash than spi flash ?
I've constaint of time, so I need to reduce the boot time.
Message Edited by kant35 on 03-23-2009 02:31 AM
Re: Boot on parallel flash is longer than Spi flash
I'm sorry for this post..
In fact it's the display which was slowly the boot.
I remove those print and now it takes about 3 secondes before starting... It's good
