Breakpoint on a "if statement"
I use Xilinx SDK 2019.1. When I set a breakpoint on an if statement, the breakpoint stops the process for every single boolean operation instead of the whole statement.
Example:
on this statement i have to press resume ten times to reach the next line.
The Status of the breakpoint looks like this:
How can I disable this behavior when I'm not in instruction stepping mode?
Hi @meinusch_kilian,
This is the expected behaviour in the SDK when setting a "Line" Breakpoint.
If you want to stop only once, you should use an "Address" breakpoint instead on the address of the If statement start.
You can set an "Address" breakpoint by double clicking on the address from the "Disassemby" view or by using the XSDB command:
     bpadd -addr 0x02013350
Best regards,
Abdallah
Best regards,
Abdallah
Hello Abdallah,
thanks for your answer.
It's a little awkward, but it works.
I guess there is no alternative to this approach?
You are welcome!
No, not as far as I know.
Best regards,
Abdallah
I found a simple solutuion!!
Just set the breakpoint on an empty line above the if statement. This way you get a line-breakpoint which is stoping only once.
Can some Mod mark this as solution?
Looks like I can't change that afterwards.
