04-04-2011 12:20 AM
I have to bpoblem SDK13.1 on WINDOWS7 x86_64 (version 6.1.7601). The SDK does not work breakpoint (Show - Unresolved breakpoint) and stop (Show - Target request failed: Failed to interrupt).
SDK.log:
!SESSION 2011-04-04 08:19:30.341 -----------------------------------------------
eclipse.buildId=Release 13.1 Build SDK_O.40d
java.version=1.6.0_21
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=cs_CZ
Command-line arguments: -os win32 -ws win32 -arch x86_64
!ENTRY org.eclipse.cdt.core 1 0 2011-04-04 08:20:22.432
!MESSAGE Indexed 'empty_application_0' (0 sources, 21 headers) in 0,28 sec: 153 declarations; 291 references; 3 unresolved inclusions; 0 syntax errors; 1 unresolved names (0,22%)
!ENTRY org.eclipse.cdt.core 1 0 2011-04-04 08:20:23.134
!MESSAGE Indexed 'empty_application_bsp_0' (49 sources, 43 headers) in 0,69 sec: 1 177 declarations; 5 862 references; 19 unresolved inclusions; 0 syntax errors; 74 unresolved names (1,04%)
Please help, thanks.
05-31-2011 06:41 PM - edited 05-31-2011 06:43 PM
anybody can give some advice? I met the same question,now!
i use SDK v12.3 in Windows7
06-01-2011 12:56 AM
Can you set the breakpoint in XMD?
06-15-2012 12:28 PM
I am seeing the same problem in SDK 14.1. I can set breakpoints just fine via the XMD console but using the more convenient interface through the main IDE does not work. I get error messages similar to those reported above.
