Building Linux kernel fails, but I see the tool in the correct location
Following the instructions given here: http://www.wiki.xilinx.com/Build+kernel
I get the following output when running make ARCH=arm UIMAGE_LOADER=0x8000 uImage:
make: arm-xilinx-linux-gnueabi-gcc: Command not found
So I run 'which arm-xilinx-linux-gnueabi-gcc'
and get '/opt/Xilinx/SDK/2015.2/gnu/arm/lin/bin/arm-xilinx/linux-gnueabi-gcc'
So I try 'ls /opt/Xilinx/SDK/2015.2/gnu/arm/lin/bin/'
and sure enough, I see arm-xilinx-linux-gnueabi-gcc.
Why is the make command failing?
Re: Building Linux kernel fails, but I see the tool in the correct location
Might have found the problem, but not the solution.
I am running this on 64-bit Debian, and when I run 'file /opt/Xilinx/SDK/2015.2/gnu/arm/lin/bin/arm-xilinx-gnueabi-gcc' it returns ELF 32-bit. So maybe I can't use this and need to sue the 64-bit. The problem is that I dont see anything indicating a 64 bit version of this tool. Is there a 64-bit arm-xilinx-gnueabi-gcc, and if so where would I find it if not the /gnu/arm/lin/bin directory?
I know for certain I have 64-bit Xilinx installed, so it should be here somewhere.
Issue resolved. Install the following before attempting anything with Xilinx tools:
libncurses5-dev
lib32z1
lib32ncurses5
lib32bz2-1.0
