Observer obernikhin
C array index problems during type cast.
EDK 11.2
I have a char array DataArr,and integer value FlagData.
I need to write Flag data to some possition in DataArr.
unsigned int * FlagDataPtr=NULL;
FlagDataPtr=(unsigned int *)&DataArr[Pos];
*FlagDataPtr=FlagData;
If Pos isn't divisible by 4 a FlagDataPtr point to nearest smaller and divisible by 4 index of DataArr;
Example Pos=14, but FlagDataPtr bind to 12 element of DataArr.
Where is error?
Tags (3)
Re: C array index problems during type cast.
I think, that issue is a feature, not an error of the GCC!
I would implement an other scenario.
uint32 iDataArr[n];
uint8  *cDataArrPtr=(uint8*)&iDataArr[0];
int pos; // 0...n
(cDataArrPtr+=4  == iDataArr++)
To get each Byte of iDataArr:
cDataArrPtr=&iDataArr[pos];
byte0=(uint8)*(cDataArrPtr+0);
byte1=(uint8)*(cDataArrPtr+1);
byte2=(uint8)*(cDataArrPtr+2);
byte3=(uint8)*(cDataArrPtr+3);
It's more  reasonable (for me) ;-)
Rgds,
Kai
Historian
Historian
obernikhin wrote:
EDK 11.2
Where is error?
What is question?
Observer obernikhin
>>What is question?
Question is: is this an compiller bug, or just some compiller parameter setting?
Coz compiller automaticly bind position of intger pointer to nearest smaller and divisible by 4 index of array.
I don't need this automaticly index shift.
uint32 iDataArr[n];
int pos; // 0...n
Rgds,
Kai
