arash9k
Can't change Microblaze MCS clock frequency.
In Vivado IPI when I change the Input Clock Frequency to anything other than 100MHz, the output clock port of MCS still shows 100MHz as the frequency. The frequency of this port is fixed and non-editable. Then when I make this port external and set the clock frequency of the input external pin to the desired clock frequency I get the following error:
[BD 41-238] Port/Pin property FREQ_HZ does not match between /microblaze_mcs_0/Clk(100000000) and /Clk(20000000)
I'm not able to change the input clock frequency of Microblaze MCS to any value other than the default. Can someone please help?
I'm using Vivado 2016.1.
goran
goran
