Clock generator problem?
   I got an error when I generate the bitstream of my design during the MAP step.
ERROR:LIT:447 - CLKINSEL of PLL_ADV symbol    "physical_group_system_i/clock_generator_0/clock_generator_0/SIG_PLL0_CLKOUT0/system_i/clock_generator_0/clock_generator_0/PLL0_INST/Using_PLL_ADV.PLL_ADV_inst" (output    signal=system_i/clock_generator_0/clock_generator_0/SIG_PLL0_CLKOUT0) is a    constant 1 (choosing CLKIN1) but CLKIN1 is not an active signal.
Xilinx offical solution of #447 simply says:
"This issue has been fixed in the "clock_generator_v3_00_a" core and is available in EDK 11.1
at:  http://www.xilinx.com/xlnx/xil_sw_updates_home.jsp "
However, I am using XPS13.4 which has clock_generator_4_03_a. It's a newer version. But the problem still exist.
I cannot figure out where the problem is. Can anyone give me a hint to solve it?
Eric
any help, please??
Could you post your MHS file or a description of how your clock generator is configured/connected?
Howard
"That which we must learn to do, we learn by doing." - Aristotle
Thanks, Howard,
  This is my MHS file, hope you can help me to figure the problem out.
PARAMETER VERSION = 2.1.0
 PORT fpga_0_clk_1_sys_clk_pin = CLK_S, DIR = I, SIGIS = CLK, CLK_FREQ = 100000000
 PORT fpga_0_rst_1_sys_rst_pin = sys_rst_s, DIR = I, SIGIS = RST, RST_POLARITY = 0
BEGIN microblaze
 PARAMETER INSTANCE = microblaze_0
 PARAMETER C_USE_BARREL = 1
 PARAMETER C_DEBUG_ENABLED = 1
 PARAMETER HW_VER = 8.20.b
 BUS_INTERFACE DLMB = dlmb
 BUS_INTERFACE ILMB = ilmb
 BUS_INTERFACE DPLB = mb_plb
 BUS_INTERFACE IPLB = mb_plb
 BUS_INTERFACE DEBUG = microblaze_0_mdm_bus
 PORT MB_RESET = mb_reset
END
BEGIN plb_v46
 PARAMETER INSTANCE = mb_plb
 PARAMETER HW_VER = 1.05.a
 PORT PLB_Clk = clk_125_0000MHz
 PORT SYS_Rst = sys_bus_reset
END
BEGIN lmb_v10
 PARAMETER INSTANCE = ilmb
 PARAMETER HW_VER = 2.00.b
 PORT LMB_Clk = clk_125_0000MHz
END
BEGIN lmb_v10
 PARAMETER INSTANCE = dlmb
END
BEGIN lmb_bram_if_cntlr
 PARAMETER INSTANCE = dlmb_cntlr
 PARAMETER HW_VER = 3.00.b
 PARAMETER C_BASEADDR = 0x00000000
 PARAMETER C_HIGHADDR = 0x00001fff
 BUS_INTERFACE SLMB = dlmb
 BUS_INTERFACE BRAM_PORT = dlmb_port
END
 PARAMETER INSTANCE = ilmb_cntlr
 BUS_INTERFACE SLMB = ilmb
 BUS_INTERFACE BRAM_PORT = ilmb_port
END
BEGIN bram_block
 PARAMETER INSTANCE = lmb_bram
 PARAMETER HW_VER = 1.00.a
 BUS_INTERFACE PORTA = ilmb_port
 BUS_INTERFACE PORTB = dlmb_port
END
BEGIN clock_generator
 PARAMETER INSTANCE = clock_generator_0
 PARAMETER C_CLKIN_FREQ = 100000000
 PARAMETER C_CLKOUT0_FREQ = 125000000
 PARAMETER C_CLKOUT0_PHASE = 0
 PARAMETER C_CLKOUT0_GROUP = NONE
 PARAMETER C_CLKOUT0_BUF = TRUE
 PARAMETER C_EXT_RESET_HIGH = 0
 PARAMETER HW_VER = 4.03.a
 PORT CLKIN = CLK_S
 PORT CLKOUT0 = clk_125_0000MHz
 PORT RST = sys_rst_s
 PORT LOCKED = Dcm_all_locked
END
BEGIN mdm
 PARAMETER INSTANCE = mdm_0
 PARAMETER C_MB_DBG_PORTS = 1
 PARAMETER C_USE_UART = 1
 PARAMETER C_BASEADDR = 0x84400000
 PARAMETER C_HIGHADDR = 0x8440ffff
 BUS_INTERFACE SPLB = mb_plb
 BUS_INTERFACE MBDEBUG_0 = microblaze_0_mdm_bus
 PORT Debug_SYS_Rst = Debug_SYS_Rst
END
BEGIN proc_sys_reset
 PARAMETER INSTANCE = proc_sys_reset_0
 PARAMETER HW_VER = 3.00.a
 PORT Slowest_sync_clk = clk_125_0000MHz
 PORT Ext_Reset_In = sys_rst_s
 PORT MB_Debug_Sys_Rst = Debug_SYS_Rst
 PORT Dcm_locked = Dcm_all_locked
 PORT MB_Reset = mb_reset
 PORT Bus_Struct_Reset = sys_bus_reset
 PORT Peripheral_Reset = sys_periph_reset
END
BEGIN bridge_connect
 PARAMETER INSTANCE = bridge_connect_0
 PARAMETER C_BASEADDR = 0xce200000
 PARAMETER C_HIGHADDR = 0xce20ffff
END
I can't see anything obvious from your MHS.
What does the synthesis report state for the clock_generator module and for the top level design? Particularly regarding the clock input.
Howard
P.S. This issue seems very similar to the message here
