Compiler wrongly generates fsqrt FPU instruction for double precision sqrt in MB
We have Microblaze with extended-fpu in our design. Compiling code with –mxl-float-sqrt and –O1/O2 optimization generates incorrect code with double-precision SQRT function and results are corrupted.
Disassembly shows compiler generates wrong (maybe) fsqrt FPU instruction for double values.
SDK: 2016.4 GCC:5.2.0
Example Code:
double x;
double res = sqrt(x);
1a0:  5b180380   fsqrt     r24, r24
1a4:  10f80000   addk    r7, r24, r0
1a8:  11190000   addk    r8, r25, r0
1ac:  10b80000   addk    r5, r24, r0
1b0:  b000fffe   imm     -2
1b4:  b9f4deb0   brlid     r15, -8528   // 3064 <__eqdf2>  (WHAT IS THIS??????)
1b8:  10d90000   addk    r6, r25, r0
1bc:  be230244   bneid   r3, 580        // 400
1c0:  10ba0000   addk    r5, r26, r0
By the way, in new version of sdk 2018.2, the problem solved and code have been compiled correctly.
Can you share the microblaze configuration? Need to be careful with compatibility between the generated core and the compiler flags.
MicroBlaze configurations are
Version 10.0/ Enable barrel shift/ FPU extended/Mul 64bit/Integer divider/ Pattern comparator/ Optimize for performance and no cache.
Compiler flags are
mb-g++ -Wall -O2 -g -c -fmessage-length=0  -mlittle-endian -mxl-barrel-shift -mxl-pattern-compare -mno-xl-soft-div -mcpu=v10.0 -mno-xl-soft-mul -mxl-multiply-high -mhard-float -mxl-float-convert -mxl-float-sqrt
For generating the issue, example file and compile procedure is attached.
main.cc
#include <math.h>
int main()
	volatile double d;
	volatile double dr;
	d = 1.44e-4;
	dr = sqrt(d);
	return 0;
Compiler commands:
mb-g++ -o main.o main.cc -O2 -c -mlittle-endian -mno-xl-soft-div -mcpu=v10.0 -mno-xl-soft-mul -mxl-multiply-high -mhard-float -mxl-float-convert -mxl-float-sqrt
mb-objdump -dr main.o > main.asm
Disassembly of object file showing the issue:
00000000 <main>:
   0:	b00094cc 	imm	-27444
   4:	3080ab3f 	addik	r4, r0, -21697
   8:	b0003f22 	imm	16162
   c:	30a0dfd6 	addik	r5, r0, -8234
  10:	3021ffc4 	addik	r1, r1, -60
  14:	fb010034 	swi	r24, r1, 52
  18:	f8810024 	swi	r4, r1, 36
  1c:	f8a10028 	swi	r5, r1, 40
  20:	fb210038 	swi	r25, r1, 56
  24:	eb010024 	lwi	r24, r1, 36
  28:	eb210028 	lwi	r25, r1, 40
  2c:	fac1002c 	swi	r22, r1, 44
  30:	fae10030 	swi	r23, r1, 48
  34:	5ad80380 	fsqrt	r22, r24       // Why calling FSQRT instruction for double ????
  38:	12f90000 	addk	r23, r25, r0
  3c:	f9e10000 	swi	r15, r1, 0
  40:	10f60000 	addk	r7, r22, r0
  44:	11170000 	addk	r8, r23, r0
  48:	10b60000 	addk	r5, r22, r0
  4c:	b0000000 	imm	0
			4c: R_MICROBLAZE_64_PCREL	__eqdf2
  50:	b9f40000 	brlid	r15, 0
select basic FPU  can correct it
