simchask
Confused about two ELF files
Why is there an option for associated ELF file for simulation sources?
Is it possible to write a testbench from the SDK, rather than writing it in VHDL?
Is the design source not loaded during simulation?
stephenm
As the GUI suggests; one is for design sources, and the other is for simulation sources.
Question is, why would I need a different ELF for simulation, and design sources? Well, lets say your application
was toggling an LED in the hardware you would slow this down so it was visable to your eye. However, in simulation, you dont really need to do this.
For example
No, you cannot write a testbench in SDK. I have added a debug techniques doc here
The simulation sources, and design source as seperate
stephenm
For example
