Custom IP infer slave port widths from master ports automatically
when I create a AXI4 slave using the "Create And Package IP" wizzard the component will infer the port width for the user signals automatically:
When I create a custom component I want to have the same behavior for my component. I've looked at the component.xml and the xgiu .tcl files but I have no idea what I have change to get the described behavior.
Martin
Re: Custom IP infer slave port widths from master ports automatically
Hi Martin,
 You can define parameters in such a way that one parameter depends on another parameter.
In IP customization parameters tab, Right click on parameter, select Edit parameter. Select the options as shown below and in the box provided write the relationship between the parameters.
Deepika.
Deepika.
Hi Deepika,
thanks for your reply! When I look at the customization parameter dialog in the example implementation there doesn't seem to be a TCL expression:
So I still don't understand how the slave component automatically takes the value from the master component?
Martin
