Visitor jackalee
Data initialize on elf for simulation
I am a beginner of vivado and sdk tool.
I am trying to simulation my ip with .elf generated with SDK.
Firtly I used Xil_out32() to write data for BRAMs on my block design.
I confirmed my ip in simulation level.
But later on I will use data from external memory like DDR3 and BRAM.
I want to initialize BRAM at this time with data I will use for my ip to confirm their operation.
I will finally initialize DDR memory later.
So I have looked through documents of xilinx and have found that updatemem tcl command will do for initialization for bram as well as ddr memory.
But I am confused some things about it.
I have prepared for a mem file. and .elf file from SDK.
For update later with bitstream file, using updatemem on vivado console is right way to do. ( Is it right?)
For simulation with elf file, I think I need to initialize .elf file with data for bram.
Is it right initializing bram with .elf file for simulation purpose?
I would like to initialize some data on bram first and when the ip starts operating,
use the initialized data for my ip.
Also I have found that mmi file and bmm file in <project name>.runs/impl .
Are these files the files ( not need to edit or regenerate ) for using updatemem tcl?
Or should I generate bmm, mmi files with other tcl command or tools or write by myself?
I am appreciating in advance for any advice and helps.
