Debug ad9361 project in SDK2016.2 can not jump into main() ,prompt "No source available for" _start ()
       I use vivado2016.2 generatedMicroblaze minimum system which based on KC705 , and then  export hardware platform ,established  AD9361 project in the SDK2016.2, with some changes, compiled, and generated. elf files,operartion in DEBUG, launching 53% after Disappear, and unable to enter the main function , and appeared "No source available for" _start () "prompt, may I ask how to amend,?
      thank you
