hejale
Debugger stops at each interrupt
Hi I'm using the tcf agent with SDK 2018.2 on windows to load and debug a simple linux application over ethernet. It works well without interrupts but when I add an interrupt to the application (e.g. timer interrupt), SKD always stops after the interrupt. This makes it impossible to debug. How can I turn this behaviour off? Best regards Heja
hejale
I found what I was looking for, I write it if somebody else is having the same question.
SDK can be instructed not stop on interrupts as follows:
Debug View:
1) Right-Click on the elf file: AppName.elf
2) Choose Signals
3) Mark Don't Stop for the used Interrupt
ibaie
Hi @hejale
When you say you are using TCF agent does it mean that you selected the "Target Communication Framework" debug type in the debug configuration wizard? We always recomend to use System Debugger option and then select the Linux application debug type.
You are mentioning that you are debugging a Linux application so where does the debugger stop on the interrupt? I mean, interrupts in Linux are handled by the kernel rather than userspace so not sure if I'm understanding the issue.
Ibai
hejale
Hello Ibai
Thank you for your reply.
I'm using System Debugger with Linux Application Debug as "Debug Type". On the target I run the tcf-agent.
The debugger stops anywhere in the code, maybe wherever it was when the interrupt occured. At this point, if I try to step, I get the attached error ("Cannot step..") but I can resume and the program runs until the next interrupt occurs.
Everything works fine when I disable the timer interrupt and instead poll the timer.
Basically I copied the code for the timer from this page:
http://man7.org/linux/man-pages/man2/timer_create.2.html
The application (C++) is statically linked and has following additional linker flags for timer_create: -lrt -lpthread
Best regards
heja
hejale
Debug View:
2) Choose Signals
