04-19-2011 11:16 PM
Hi all,
I´m starting with Microblaze, and I´ve just found the first problems. I´m working with a SP601 board and I wanted to download the "test_peripheral" example that is available in the SDK. However, when the project is generated and compiled, and error ocurrers:
"region ilmb_cntlr_dlmb_cntlr is full"
"section .init [address range] overlaps section text"
....similar ones
"section .rodata lma 0x90 overlaps previous sections"
I´ve been having a look in the forum and in many threads people suggest to regenerate the linker script. I´ve done it, but with no success. I´m wondering why this is happening since it is the source autogenerated by the SDK. With other examples (HelloWorld, and so) it works fine..
Can someone give me a clue?
Thanks a lot
04-20-2011 07:35 AM
open EDK, go to Adresses and resize the space from 8k (i guess) to 16k for dlmb_cntlr, ilmb_cntlr adjust automatically, export to sdk again and peripheral-test will work fine, I think.
regards
04-20-2011 08:44 AM
04-20-2011 09:57 AM
All it means is that you don't have sufficient memory space to load and run your application. You can use a bigger external memory or a bigger LMB memory. SDK tries to pick the external memory if it is available, so I suspect your design doesn't have external memory.
04-25-2011 03:08 AM
Hi all,
Thank you very much for your answer. All of you are rigth and the problem was related to the memory size. Now, after having resized the memory, it works fine
Thanks again!
