Difference between arm compilers
I just would like to know the difference between the following ARM toolchain and which one can work as a replacement for the other:
  • aarch64-gnu-linux-gcc
  • aarch64-xilinx-linux-gcc
  • arm-none-eabi-gcc
 My goal is to convert an .elf file into a shared library (.so) file. So, I have previously mentioned compilers installed on my machine. Given my goal to convert the ELF file to the shared library for an application deployed on the ZCU104 FPG, which one to use?
I managed to solve my issue. In UG1414, the following command is used:
aarch64-linux-gnu-gcc \
--sysroot=~/petalinux_sdk/sysroots/aarch64-xilinx-linux \
-fPIC -shared dpu_xxxxxx_*.elf -o libdpumodelxxxxxx.so
This should work instead of using aarch64-xilinx-linux-gcc.
I would suggest, based upon the open question,
which ever one you can get the best support for,
Hi @drjohnsmith
So, there is no significant difference between these two compilers?
depends upon your definition of significant !
as your asking, Im guessing , you have limited experience in the different compilers,
based purely upon that , sounds like you will need some support,
so I'd go for the one you can get the best support for.
one is built with crosstool-ng and aarch64-xilinx-linux-gcc with yocto frame work. However, they should function the same
There is a nomenclature for gnu cross compilers, that is:  arch-vendor-(os-)abi
So both compilers you mention are for aarch64 architecture and having linux as OS. The difference is the vendor (who makes it), GNU in one case, Xilinx in other. Are they the same? It depends on how big is the magnifier you look through. In most cases, it will be the same.
The last one (arm-none-eabi-gcc) is another thing. It is for arm (not aarch64) architecture and compiles executable binaries (eabi = embedded application binary interface) not, for example, the OS itself.
Hi @archangel-lightworks@stephenm@drjohnsmith,
Thanks a lot for giving such information.
I am asking because I am running through a weird problem. I am trying to compile a file using the following command:
aarch64-xilinx-linux-gcc -fPIC -shared dpu_thin_1stage_dense_0.elf -o libdpumodelthin_1stage_dense.so
As can be noted, I am working with Vitis AI stack flow to run my model on the DPU.
However, I constantly get the same following error:
/home/user/petalinux_sdk/sysroots/x86_64-petalinux-linux/usr/libexec/aarch64-xilinx-linux/gcc/aarch64-xilinx-linux/9.2.0/real-ld: cannot find crti.o: No such file or directory
/home/user/petalinux_sdk/sysroots/x86_64-petalinux-linux/usr/libexec/aarch64-xilinx-linux/gcc/aarch64-xilinx-linux/9.2.0/real-ld: cannot find crtbeginS.o: No such file or directory
/home/user/petalinux_sdk/sysroots/x86_64-petalinux-linux/usr/libexec/aarch64-xilinx-linux/gcc/aarch64-xilinx-linux/9.2.0/real-ld: cannot find -lgcc
/home/user/petalinux_sdk/sysroots/x86_64-petalinux-linux/usr/libexec/aarch64-xilinx-linux/gcc/aarch64-xilinx-linux/9.2.0/real-ld: cannot find -lgcc_s
/home/user/petalinux_sdk/sysroots/x86_64-petalinux-linux/usr/libexec/aarch64-xilinx-linux/gcc/aarch64-xilinx-linux/9.2.0/real-ld: cannot find -lc
/home/user/petalinux_sdk/sysroots/x86_64-petalinux-linux/usr/libexec/aarch64-xilinx-linux/gcc/aarch64-xilinx-linux/9.2.0/real-ld: cannot find crtendS.o: No such file or directory
/home/user/petalinux_sdk/sysroots/x86_64-petalinux-linux/usr/libexec/aarch64-xilinx-linux/gcc/aarch64-xilinx-linux/9.2.0/real-ld: cannot find crtn.o: No such file or directory
collect2: error: ld returned 1 exit status
However, when I use the aarch64-gnu-linux-gcc, it compiles the file successfully with no errors. Would you please help me why this is happening? And how to solve it?
The problem is caused due to your sysroot is not found
You need to specify your sysroot directory as an argument while compiling;
--sysroot=/YOUR_DIRECTORY
Helper to see is it in your path;
aarch64-xilinx-linux-gcc -print-search-dirs
@asobeih
that's a much better question to ask on a forum,
Hi @alperuzgec@drjohnsmith , @archangel-lightworks , @stephenm,
Thank you. I followed your advice and here is what I did:
  1. I checked the search path using this command:
aarch64-xilinx-linux-gcc -print-search-dirs​
And here is what I got:
  • I set the --sysroot to my sysroot path found in the toolchain installation directory, which is:  /home/user/petalinux_sdk/sysroots/
    Yet, I got the same errors mentioned in my previous reply
  • I searched for the crti.o file, and found it under this directory: /home/user/petalinux_sdk/sysroots/aarch64-xilinx-linux/usr/lib . I passed this path to my -I, -L, and --sysroot, each at a time, yet, same errors
  • the "real-ld" is a symbolic link. It is not a directory that may contain a library or something.
  • I printed my $PATH library, and here is what I found (I do not set it at all. It gets set by sourcing the toolchain script):
    /home/user/petalinux_sdk/sysroots/x86_64-petalinux-linux/usr/bin:/home/user/petalinux_sdk/sysroots/x86_64-petalinux-linux/usr/sbin:/home/user/petalinux_sdk/sysroots/x86_64-petalinux-linux/bin:/home/user/petalinux_sdk/sysroots/x86_64-petalinux-linux/sbin:/home/user/petalinux_sdk/sysroots/x86_64-petalinux-linux/usr/bin/../x86_64-petalinux-linux/bin:/home/user/petalinux_sdk/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux:/home/user/petalinux_sdk/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux-musl:/home/user/bin:/home/user/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
  • I printed the $LD_LIBRARY_PATH and it was empty.
Again, I would like to point out that the file that I am trying to compile was successfully compiled by aarch64-gnu-linux-gcc compiler. I am actually following this tutorial:
https://developer.xilinx.com/en/articles/medical-ai-application-acceleration-with-xilinx-vitis-ai.html
Any advice on this?
@asobeih it seems your issue is not a difference in compiler but just in case.
You can find out how a GCC compiler was build and will operate with these 2 commands:
gcc -dM -E - < dev/null tells you all the internal #define
gcc --print-multi-lib tells you all the type of libraries it can work with (e.g. hard vs soft float)
Hi @ericv,
I followed your instructions and the following is the output that I got:
Is this output what I should expect? How would this help with solving my issue?
Regarding your comment on the difference of the compilers, my point here is that I did not face the issue I am discussing here when I used the aarch64-gnu-linux-gcc compiler as everything worked smoothly. My problems started when I used the aarch64-xilinx-linux-gcc compiler.
The main point behind my question about the difference was that if there is no true difference between the Xilinx toolchain and GNU toolchain, I would surely stick to the GNU toolchain to avoid this weird issue.
Let me know your thoughts, please
@asobeih First, my mistake as it should obviously be /dev/null and not dev/null.  Is that what is expected? Refer to
https://stackoverflow.com/questions/37418986/how-to-interpret-the-output-of-gcc-print-multi-lib
for an simplified explanation for --print-multi-lib. The output of -dM -E is self explanatory.
@ericv Thanks a lot for helping me out. I just cannot understand how this should help with solving my issue. Would you please clarify this point?
@drjohnsmith@alperuzgec@archangel-lightworks@stephenm, your help is greatly appreciated. I am still looking forward to your response.
