Participant yxiao0308
Does Windows Vista fully support Xilinx ISE Design suite as Windows XP?
Hi, guys,
Since I got some unknown segmentation error when I tried to generating bit-stream for board XC5VLX110T on EDK 11.4 via Linux Enterprise Redhat 5.4, which can be found at http://forums.xilinx.com/xlnx/board/message?board.id=EDK&thread.id=13226, probably I will try to install Windows Vista as OS.
I check on the link: http://www.xilinx.com/ise/ossupport/index.htm
It says Vista fully support ISE Design suite.
But when I went to: http://www.xilinx.com/publications/matrix/Software_matrix.pdf?KeepThis=true&TB_iframe=true&height=800&width=600
It says Vista doesn't support System Generator for DSP.
Which one should I follow?
Yang
Re: Does Windows Vista fully support Xilinx ISE Design suite as Windows XP?
Please check the link
This shows the supported OS along with the softwares.
Thnx.
Thnx.
