Driving a PLB
Can a custom IP be read from and written to using only the default PLB slave signals:
Bus2IP_Clk
Bus2IP_Reset
Bus2IP_Addr
Bus2IP_CS
Bus2IP_RNW
Bus2IP_Data
Bus2IP_BE
Bus2IP_RdCE
Bus2IP_WrCE
IP2Bus_Data
IP2Bus_RdAck
IP2Bus_WrAck
IP2Bus_Error
Is there any documentation using these signals to respond to the PLB master?
I think I found the documentation I was looking for.
File is called plbv46_slave.pdf and was buried in      10.1/EDK/hw/XilinxProcessorIPLib/pcores/plbv46_slave_single_v1_01_a/doc/
You may also find this useful if you are looking for information that goes beyond what is in that datasheet:
http://www.xilinx.com/support/answers/30189.htm (128bitplbbus_v4.6.pdf - Where can I find the 128-bit PLB Bus Architecture Specifications from IBM?)
Cheers,
bt
I have read through the documentation and am trying to do a simple read from my IP to the PPC. The only thing I am able to read back is all zeroes. Any ideas? Here are important portions of my code.
    --CS declaration
    Bus2IP_CS  : in  std_logic_vector(0 to 0);
    slv_read_ack <= Bus2IP_CS(0) and Bus2IP_RNW;
    Test: process( Bus2IP_CLK ) is
    begin
        if Bus2IP_CLK'event and Bus2IP_CLK = '1' then
            case Bus2IP_Addr is
                when x"00000f00"    => slv_data_bus <= x"11110000";
                when x"00000f04"    => slv_data_bus <= x"22220000";
                when others            => slv_data_bus <= x"33330000";
            end case;
        end if;
    end process TEST;
    IP2Bus_Data  <=    slv_data_bus when slv_read_ack = '1' else
                                 x"deadc0de";
    IP2Bus_WrAck <= '0';
    IP2Bus_RdAck <= slv_read_ack;
    IP2Bus_Error <= '0';
My program only tries to read from address F00 and F04, no writing at all. According to timing diagram in plbv46_slave_single.pdf on page 14, as soon as Bus2IP_CS and Bus2IP_RNW are asserted I present my data with a read ack and things should be fine. But it appears I am timing out and the PLb returns all zeroes... Any thoughts?
I have the similar question and hoping anyone can give an answer.
tarzan
