Visitor frenz112
EDK Installation
I have Xilinx ISE Design suite 10.1 already installed in my computer but want to use EDK 9.1 as a few applications are posing compatibility problems with EDK 10.1. So I uninstalled EDK 10.1 letting other ISE design suite 10.1 features untouched and installed EDK 9.1 from my installation DVD. But when now I try an open EDK 9.1 certain command window appears displaying messaage...
$XILINX does not point to an iSE 9.1 installation
Press enter to close.
Do I have to uninstall the whole  ISE Design suite 10.1 before installing EDK 9.1??
Re: EDK Installation
Hello.
For 9.1 version:
Go to environment variable and in the System Variable give variable value as "installation_drive:\Xilinx91i" for variable name XILINX
and give variable value as "installation_drive:\EDK" for variable name XILINX_EDK.
Make sure the installation drive is same in both the cases.
In future if you have to switch back to 10.1 then
give variable value as "installation_drive:\Xilinx\10.1\ISE" for variable name XILINX
and give variable value as "installation_drive:\Xilinx\10.1\EDK" for variable name XILINX_EDK.
Best of luck.
Unlimited in my Limits.
You don't have to uninstall anything (ISE 10.1 or EDK 10.1).
EDK 9.1 needs to work with ISE 9.1. If you also have ISE9.1 installed, please change the environment variable  $XILINX to point to the ISE 9.1 installation directory.
-XF
Visitor frenz112
I'll install ISE 9.1 right now. Can you tell me how to change environment variable $XILINX (using windows XP). I just want to be sure I m doing it right.
Thanks a lot.
Hello.
For 9.1 version:
Best of luck.
