Visitor akur061
EDK LUT mapping failure. MapLib:979 - LUT3 symbol error
I have recently made a project which uses two AXI masters to interact with two BRAM controllers in Xilinx EDK. When I try generating a bit file, the program fails during the mapping phase in which maps the designs to the LUTs.
The 5 errors, I've received are as followed .
ERROR:MapLib:979 - LUT3 symbol
ERROR:MapLib:979 - LUT6 symbol
ERROR:MapLib:978 - LUT3 symbol
ERROR:MapLib:978 - LUT6 symbol
Does anyone have any suggestions on what may be causing these errors? I have also included a more detailed error report below.
Thanks for reading,
A
"axi_i_bus/axi_i_bus/si_converter_bank/gen_conv_slot[0].clock_conv_inst/gen_a sync_readwrite.asyncfifo_rw/U0/xst_fifo_generator/gaxi_full_lite.gwrite_ch.gw ach2.axi_wach/grf.rf/gntv_or_sync_fifo.mem/gdm.dm/dout_i_60_dpot" (output
signal=axi_i_bus/axi_i_bus/si_converter_bank/gen_conv_slot[0].clock_conv_inst
/gen_async_readwrite.asyncfifo_rw/U0/xst_fifo_generator/gaxi_full_lite.gwrite
_ch.gwach2.axi_wach/grf.rf/gntv_or_sync_fifo.mem/gdm.dm/dout_i_60_dpot) has
input signal
ach2.axi_wach/grf.rf/gntv_or_sync_fifo.mem/gdm.dm/_n0014<60>" which will be
trimmed. See Section 5 of the Map Report File for details about why the input
signal will become undriven.
"axi_i_bus/axi_i_bus/si_converter_bank/gen_conv_slot[0].clock_conv_inst/gen_a sync_readwrite.asyncfifo_rw/U0/xst_fifo_generator/gaxi_full_lite.gwrite_ch.gw ach2.axi_wach/grf.rf/gntv_or_sync_fifo.mem/gdm.dm/dout_i_61_dpot" (output
_ch.gwach2.axi_wach/grf.rf/gntv_or_sync_fifo.mem/gdm.dm/dout_i_61_dpot) has
input signal
ach2.axi_wach/grf.rf/gntv_or_sync_fifo.mem/gdm.dm/_n0014<61>" which will be
"axi_i_bus/axi_i_bus/si_converter_bank/gen_conv_slot[0].clock_conv_inst/gen_a sync_readwrite.asyncfifo_rw/U0/xst_fifo_generator/gaxi_full_lite.gwrite_ch.gw dch2.axi_wdch/grf.rf/gntv_or_sync_fifo.mem/gdm.dm/dout_i_36_dpot1" (output
_ch.gwdch2.axi_wdch/grf.rf/gntv_or_sync_fifo.mem/gdm.dm/dout_i_36_dpot1) has
input signal
dch2.axi_wdch/grf.rf/gntv_or_sync_fifo.mem/gdm.dm/_n0014<36>" which will be
WARNING:MapLib:701 - Signal RS232_Uart_1_sin connected to top level port
RS232_Uart_1_sin has been removed.
an equation that uses input pin I2, which no longer has a connected signal.
Please ensure that all the pins used in the equation for this LUT have
signals that are not trimmed (see Section 5 of the Map Report File for
details on which signals were trimmed).
an equation that uses input pin I5, which no longer has a connected signal.
WARNING:MapLib:41 - All members of TNM group
"TNM_TIG_DDR3_SDRAM_IODELAY_CTRL_RDY_O_SYNCH" have been optimized out of the
design.
"TNM_TIG_DDR3_SDRAM_IODELAY_CTRL_RST_SYNCH" have been optimized out of the
design.
WARNING:MapLib:48 - The timing specification
"TS_TIG_DDR3_SDRAM_IODELAY_CTRL_RDY_O_SYNCH" has been discarded because its
TO group (TNM_TIG_DDR3_SDRAM_IODELAY_CTRL_RDY_O_SYNCH) was optimized away.
"TS_TIG_DDR3_SDRAM_IODELAY_CTRL_RST_SYNCH" has been discarded because its TO
group (TNM_TIG_DDR3_SDRAM_IODELAY_CTRL_RST_SYNCH) was optimized away.
Error found in mapping process, exiting...
Errors found during the mapping phase. Please see map report file for more
details. Output files will not be written.
Design Summary
Number of errors : 6
Number of warnings : 5
ERROR:Xflow - Program map returned error code 2. Aborting flow execution...
make: *** [__xps/system_routed] Error 1
Done!
Visitor akur061
Re: EDK LUT mapping failure. MapLib:979 - LUT3 symbol error
I should also add that the Board I'm using is a Xilinx Virtex 6 ML605.
I am having a similar issue.  Everything was fine until I starting playing with Plan Ahead and then opened up the core to make a change, now it wouldgenerate the BitStream...
I am using a custom board with a Virtex-6
