EDK - SDK
 I trying with xps microblaze  using edk and sdk for custom spartan 6 fpga,
I make project for GPIO, I have question how gpio pin assigned?  how to add constraint files.
l solve it using EDK
you would add the constraints via the ucf file in ISE
How it link to sdk / edk?
