ELF size reduction techniques
I am working on a Kintex-7 project in Vivado /SDK 2018.1 and am needing to reduce my ELF size so I can reduce my BRAM size in my implementation.   The current ELF size is 332K if I use -Os in the compiler.
Is there some way is SDK to breakdown what files/functions etc are taking the space so I can start focusing on what I need to remove to reduce the size?    I am hoping for something like the utilization report you can get in Vivado.
Tim
Re: ELF size reduction techniques
First, I would try changing the SDK build configuration for your app from ‘Debug’ to ‘Release’.
The size of functions is avaliable by running 'mb-objdump.exe -D yourApp.elf' or simply by double clicking on the elf within SDK.
@johnmcd ,
   Thanks for the response.  I wasn't aware of the Release/Debug settings.   Setting it to Release it went from 332K down to 313K where my goal is <256K so I can change my BRAM from 512K to 256K.
   See below for what is seen when I double click the ELF file.   Is this the section you are talking about?   Since this is Release, I wonder why there is so much space being used for ".debug_*?
Sections:
Idx Name          Size      VMA       LMA       File off  Algn
  0 .vectors.reset 00000008  00000000  00000000  00000094  2**2
                  CONTENTS, ALLOC, LOAD, READONLY, CODE
  1 .vectors.sw_exception 00000008  00000008  00000008  0000009c  2**2
  2 .vectors.interrupt 00000008  00000010  00000010  000000a4  2**2
  3 .vectors.hw_exception 00000008  00000020  00000020  000000b4  2**2
  4 .text         0003f844  00000050  00000050  000000bc  2**2
                  CONTENTS, ALLOC, LOAD, CODE
  5 .init         0000003c  0003f894  0003f894  0003f900  2**2
  6 .fini         00000020  0003f8d0  0003f8d0  0003f93c  2**2
  7 .ctors        00000008  0003f8f0  0003f8f0  0003f95c  2**2
                  CONTENTS, ALLOC, LOAD, DATA
  8 .dtors        00000008  0003f8f8  0003f8f8  0003f964  2**2
  9 .rodata       0000ce64  0003f900  0003f900  0003f96c  2**2
                  CONTENTS, ALLOC, LOAD, READONLY, DATA
 10 .sdata2       00000004  0004c764  0004c764  0004c7d0  2**0
                  ALLOC
 11 .data         00000d34  0004c768  0004c768  0004c7d0  2**2
 12 .sdata        00000004  0004d49c  0004d49c  0004d504  2**0
                  ALLOC
 13 .sbss         00000000  0004d4a0  0004d4a0  0004d504  2**0
                  CONTENTS
 14 .bss          00004b5c  0004d4a0  0004d4a0  0004d504  2**2
                  ALLOC
 15 .heap         00001004  00051ffc  00051ffc  0004d504  2**0
                  ALLOC
 16 .stack        00001000  00053000  00053000  0004d504  2**0
                  ALLOC
 17 .debug_frame  000006ec  00000000  00000000  0004d504  2**2
                  CONTENTS, READONLY, DEBUGGING
 18 .debug_info   0000db6c  00000000  00000000  0004dbf0  2**0
 19 .debug_abbrev 00003f96  00000000  00000000  0005b75c  2**0
 20 .debug_loc    00004f5f  00000000  00000000  0005f6f2  2**0
 21 .debug_aranges 000004a8  00000000  00000000  00064658  2**3
 22 .debug_ranges 00000560  00000000  00000000  00064b00  2**0
 23 .debug_line   000070d8  00000000  00000000  00065060  2**0
 24 .debug_str    00000fda  00000000  00000000  0006c138  2**0
Tim
Have a look at the hw and sw techniques seen in the solution here to try reduce your code size
https://forums.xilinx.com/t5/Embedded-Processor-System-Design/Why-is-Microblaze-Code-Size-too-big/td-p/702313
