ERROR:EDK - cpu () - Couldn't figure out compiler's library directory
While building my project having TEMAC on sp6, with eval license, i am getting this error
ERROR:EDK - cpu () - Couldn't figure out compiler's library directory .
Is it because eval license is not installed properly? Or there is some other reason?
Attached is the screenshot from EDK, which pops out when i start EDK having TEMAC.
Saransh
Problem is solved. Actually the compiler was set to mbbgcc -c instead of mbgcc, due to which cpu() was not able to find out compiler's directory
Since you are using soft core on Spartan-6, have you generated an eval license online?
This AR has more information about it.
http://www.xilinx.com/support/answers/29828.htm
BR,
Yan Shun Li
